Browse Forums Building A New House Re: Who is building with Beechwood 14741Apr 11, 2017 10:32 am KDRB... its still on going.. Appears that the construction manager has taken the task on. he advised yesterday that they may stop all payments to the concrete contractor till its sorted. He advised that they have an engineer and a concreter attending tomorrow at 9-930 to start to fix it. when we spoke with the construction manager he wasn't impressed at all its taken 6 weeks + to fix and is now delaying work further.. the manager has been very helpful in the last few days getting it sorted. I don't think I have posted any pictures of how wrong it is so attached a few pictures of the issues Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ the inside of the footing to left of screen not wide enough to support the weight of 470mm brick piers and the footing is 500mm out from the wall.. pink line to the right is excess.. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ when we got plans done we spent 2 months placing the house on the block so to allow access down this side of the house to access the water so we can put boats and jet skis in. it got to the point that we even set flags up and drove around to ensure we could still maintain a vehicle width so we had access to water. as you can see in this picture the storm water pipe is a good mt + off the line of the house and right in the middle of the access point because the footing comes out to the pipe well away from where it should be. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ this is the back section of the house the footing is 500mm to 700mm higher than it should be. It was meant to be at ground level and is well above ground level. having the footing 500mm to 700mm higher than ground level creates drama when we go to put the deck on out the back and we will lose the under storage under the deck which is not what we wanted. All in all its been an issue for a while. Brother inlaw works at the kitchen joint where our kitchen is being made and he advised that our kitchen has been in production for the last week with delivery set for the 20th of this month which isn't going to happen as they unable to progress till the footing is dealt with then they still have to do roof, gutters, electrical rough in gyprock before they can get the kitchen in. its looking like by the time it will take to fix delaying the build process for 2 months... Todd the construction manager wasn't to impressed its taken that long to get fixed however has assured it will be sorted ASAP. the poor construction supervisor isn't impressed as he is unable to proceed with building any further until its sorted... and the contract brick company (might I add are the best brickies I have seen in our area in a long time.. massive attention taken to detail to ensure that everything looks fantastic even to the point of cutting extremely small slithers of bricks instead of them building mortar bed up and the grout lines are great nil defects its a huge relief, bricks not cracked to fit like most do. they cut to shape etc.) now have to come back once the footing is done to finish off the brick piers on the footing... the concreter said its a difficult fix to get the height right which I don't see how it could be... they have a full contour plan with them and can take levels from numerous spots.. if they can get the slab heights right a footing height shouldn't be to hard at all. sooo all in all sorry for the long post but that's were we at hopefully its sorted or started tomorrow and if nothing happens by start of next week we will escalate it further however after the calls with the construction manager I'm confident it will be sorted tomorrow.... but on a positive note....... bricks finished today hopefully will get to upload some pictures this arvo.. Re: Who is building with Beechwood 14743Apr 12, 2017 11:12 pm Imagine when your bricks are cleaned Tom...Looking great now...what's your brick again? http://buildingourhumblehome.blogspot.com Land Deposit - 20.08.2016 Land Registered - 27.09.2016 Land Settlement - 07.11.2016 House Deposit - 27.11.2016 House Contracts - 16.02.2017 House Build Starts - 10.04.2017 Building with Beechwood Homes buildingourhumblehome.blogspot.com.au Re: Who is building with Beechwood 14744Apr 12, 2017 11:29 pm tapasr_Lexia4 Imagine when your bricks are cleaned Tom...Looking great now...what's your brick again? http://buildingourhumblehome.blogspot.com Land Deposit - 20.08.2016 Land Registered - 27.09.2016 Land Settlement - 07.11.2016 House Deposit - 27.11.2016 House Contracts - 16.02.2017 House Build Starts - 10.04.2017 Building with Beechwood Homes Rosewood from the wilderness range due to them being exposure grade bricks Re: Who is building with Beechwood 14745Apr 13, 2017 12:17 am Sorry Tom, I think you did answer that question already...Thanks heaps and again great looking bricks indeed http://buildingourhumblehome.blogspot.com Land Deposit - 20.08.2016 Land Registered - 27.09.2016 Land Settlement - 07.11.2016 House Deposit - 27.11.2016 House Contracts - 16.02.2017 House Build Starts - 10.04.2017 Building with Beechwood Homes buildingourhumblehome.blogspot.com.au Re: Who is building with Beechwood 14748Apr 15, 2017 12:33 pm Hi everyone ive been following this thread for quite some time but im starting to feel like a bit of a stalker so finally decided to join lol. We are building a Moscato 5 and have just had our piers done. Im just trying to finalise out electrical plan and I was just wondering what everyone has done with lights in the kitchen. We are having 3 pendants over the island bench but I was wondering about lighting the rest of the kitchen, do most people change from the standard light to a few downlights or can you get some sort of lighting under the upper cupboards? will it look weird with the pendants if we keep the standard light. Also what about lighting for the front of the house. We are having the classic 3 façade so I was thinking of either downlights in the eves or sconce lights on either end and maybe the brick pillar? Im trying to avoid having to go to Sydney for our electrical appointment if I can as we did most of our electrical stuff at contracts and there is only a few extras we want to add. Also NBN, we don't have it here yet so should I get them to set it up ready or just leave it for now? I just wanted to say a huge thanks to everyone for sharing all your tips this thread has been a lifesaver so far. Re: Who is building with Beechwood 14749Apr 15, 2017 1:23 pm Tom2016 600x300 floor tiles stacked or 1/3 offset. It's the only thing we still not decide on. Anyone have any pictures of the 600x 300 that are stacked. What did you decide with this? I think it depends on your tile. We are using heartwood tiles so have paid extra to have them 1/3 offset as I think they look better this way but for a plain tile I think it would look good either way. Re: Who is building with Beechwood 14750Apr 15, 2017 2:18 pm newb Tom2016 600x300 floor tiles stacked or 1/3 offset. It's the only thing we still not decide on. Anyone have any pictures of the 600x 300 that are stacked. What did you decide with this? I think it depends on your tile. We are using heartwood tiles so have paid extra to have them 1/3 offset as I think they look better this way but for a plain tile I think it would look good either way. We decided to stay with stacked. Due to having a split. Looking at it we think it will flow better. Re: Who is building with Beechwood 14751Apr 15, 2017 2:26 pm newb Hi everyone ive been following this thread for quite some time but im starting to feel like a bit of a stalker so finally decided to join lol. We are building a Moscato 5 and have just had our piers done. Im just trying to finalise out electrical plan and I was just wondering what everyone has done with lights in the kitchen. We are having 3 pendants over the island bench but I was wondering about lighting the rest of the kitchen, do most people change from the standard light to a few downlights or can you get some sort of lighting under the upper cupboards? will it look weird with the pendants if we keep the standard light. Also what about lighting for the front of the house. We are having the classic 3 façade so I was thinking of either downlights in the eves or sconce lights on either end and maybe the brick pillar? Im trying to avoid having to go to Sydney for our electrical appointment if I can as we did most of our electrical stuff at contracts and there is only a few extras we want to add. Also NBN, we don't have it here yet so should I get them to set it up ready or just leave it for now? I just wanted to say a huge thanks to everyone for sharing all your tips this thread has been a lifesaver so far. We are going to put oyster light in the kitchen as the main light as well as 3 pendants over the 3mt island bench. The oysters we using are LED and has a built in dimmer so no need for anything different in wiring. We found that the downlights through bw and the electrical contractors were a bit over priced. In saying that we added them to the extended roof line and entrance as they will be a bit hard to change over later. Lighting took forever to decide on sooo many choices and effects. Different lights shadow so depending on what you want the light to do narrows down the choice. We ended up putting 3 lights out the front facade all on sensors. Choices are endless just make sure you go over your electrical plan very well before you sign off it's one of those things it's easier and cheaper to get right now even if it cost a bit more now as it will save you in the long run NBN was a tricky one. They will try and upsell you for optic fibre throughout the house. It's pointless depending on the type of NBN connection you will be provided with from the node. Most are copper from the node to the house so the expense of fibre isn't worth it Re: Who is building with Beechwood 14752Apr 15, 2017 9:21 pm newb Hi everyone ive been following this thread for quite some time but im starting to feel like a bit of a stalker so finally decided to join lol. We are building a Moscato 5 and have just had our piers done. Im just trying to finalise out electrical plan and I was just wondering what everyone has done with lights in the kitchen. We are having 3 pendants over the island bench but I was wondering about lighting the rest of the kitchen, do most people change from the standard light to a few downlights or can you get some sort of lighting under the upper cupboards? will it look weird with the pendants if we keep the standard light. Also what about lighting for the front of the house. We are having the classic 3 façade so I was thinking of either downlights in the eves or sconce lights on either end and maybe the brick pillar? Im trying to avoid having to go to Sydney for our electrical appointment if I can as we did most of our electrical stuff at contracts and there is only a few extras we want to add. Also NBN, we don't have it here yet so should I get them to set it up ready or just leave it for now? I just wanted to say a huge thanks to everyone for sharing all your tips this thread has been a lifesaver so far. Welcome to the group Newb. I think we're almost in the same stage our electrical apptmt is scheduled on the 27th. I have a bit of a plan as to how we're going to do things but definitely will not do downlights with Beechwood only for the reason that it's a bit too expensive. Hubby knows of someone who is an electrician so we thought we'd do it after the handover but there are certain things like the lights outside near the post or the Moorooka I'm going to ask Southwest electricals to do that for us. There are certain things that's going to be hard to do after the handover so even if it's a bit expensive I suppose it's better to be doing it during that time than having to redo certain things afterwards. Pretty much I'm taking ideas from this group as well and also trying to imagine in my head what we needed. PowerPoints wise well, I wanted one on each side of the island bench as we live to cook and bake so that should come handy and then a few more in the theatre room as we're thinking of using that as a study room for the children as well and then extra PowerPoint in the Masters because my husband has a CPAP machine when he sleeps so we needed sort of heaps of power points in there as well... Where are you building? http://buildingourhumblehome.blogspot.com Land Deposit - 20.08.2016 Land Registered - 27.09.2016 Land Settlement - 07.11.2016 House Deposit - 27.11.2016 House Contracts - 16.02.2017 House Build Starts - 10.04.2017 Building with Beechwood Homes buildingourhumblehome.blogspot.com.au Re: Who is building with Beechwood 14753Apr 15, 2017 9:22 pm newb Tom2016 600x300 floor tiles stacked or 1/3 offset. It's the only thing we still not decide on. Anyone have any pictures of the 600x 300 that are stacked. What did you decide with this? I think it depends on your tile. We are using heartwood tiles so have paid extra to have them 1/3 offset as I think they look better this way but for a plain tile I think it would look good either way. Newb, is your heartwood tiles standard? Are you on the Genesys range? http://buildingourhumblehome.blogspot.com Land Deposit - 20.08.2016 Land Registered - 27.09.2016 Land Settlement - 07.11.2016 House Deposit - 27.11.2016 House Contracts - 16.02.2017 House Build Starts - 10.04.2017 Building with Beechwood Homes buildingourhumblehome.blogspot.com.au Re: Who is building with Beechwood 14754Apr 17, 2017 1:54 pm Hi yes they are standard but if you want them in the 1/3 pattern then you have to pay extra so I don't think of them as standard as I personally would not have them stacked as a floor tile. Thanks for the welcome, yes we are almost at the same stage i think you have been just ahead of me so far. I have already put extra power points in each of the bedrooms as we only have one now and its not enough, plus one extra in the kitchen. Its so hard to know what to put in ive got my plan sitting on my coffee table with the extra electrical i am thinking of and just keep checking over it every time i sit down lol. Re: Who is building with Beechwood 14755Apr 17, 2017 2:02 pm Tom2016 newb Hi everyone ive been following this thread for quite some time but im starting to feel like a bit of a stalker so finally decided to join lol. We are building a Moscato 5 and have just had our piers done. Im just trying to finalise out electrical plan and I was just wondering what everyone has done with lights in the kitchen. We are having 3 pendants over the island bench but I was wondering about lighting the rest of the kitchen, do most people change from the standard light to a few downlights or can you get some sort of lighting under the upper cupboards? will it look weird with the pendants if we keep the standard light. Also what about lighting for the front of the house. We are having the classic 3 façade so I was thinking of either downlights in the eves or sconce lights on either end and maybe the brick pillar? Im trying to avoid having to go to Sydney for our electrical appointment if I can as we did most of our electrical stuff at contracts and there is only a few extras we want to add. Also NBN, we don't have it here yet so should I get them to set it up ready or just leave it for now? I just wanted to say a huge thanks to everyone for sharing all your tips this thread has been a lifesaver so far. We are going to put oyster light in the kitchen as the main light as well as 3 pendants over the 3mt island bench. The oysters we using are LED and has a built in dimmer so no need for anything different in wiring. We found that the downlights through bw and the electrical contractors were a bit over priced. In saying that we added them to the extended roof line and entrance as they will be a bit hard to change over later. Lighting took forever to decide on sooo many choices and effects. Different lights shadow so depending on what you want the light to do narrows down the choice. We ended up putting 3 lights out the front facade all on sensors. Choices are endless just make sure you go over your electrical plan very well before you sign off it's one of those things it's easier and cheaper to get right now even if it cost a bit more now as it will save you in the long run NBN was a tricky one. They will try and upsell you for optic fibre throughout the house. It's pointless depending on the type of NBN connection you will be provided with from the node. Most are copper from the node to the house so the expense of fibre isn't worth it I would love to have a split in my house its something i have always loved. Im not really a huge fan of downlights as i think you need too many to have any decent light and they are so expensive - but the do look pretty . I love the oyster light idea, we have one now in our kitchen and i don't know why i didn't think of it before. I think i will do that and then put a couple of outside lights on the front and i will put some sort of lighting over the vanity mirrors. All the NBN stuff is over my head, i will probably leave it for now. I think I have a little bit of time before i have to finalise my electrical so i usually look over it a couple of times a day. I would much rather do it now as I know i wont do it later lol. Re: Who is building with Beechwood 14756Apr 17, 2017 4:47 pm newb Hi yes they are standard but if you want them in the 1/3 pattern then you have to pay extra so I don't think of them as standard as I personally would not have them stacked as a floor tile. Thanks for the welcome, yes we are almost at the same stage i think you have been just ahead of me so far. I have already put extra power points in each of the bedrooms as we only have one now and its not enough, plus one extra in the kitchen. Its so hard to know what to put in ive got my plan sitting on my coffee table with the extra electrical i am thinking of and just keep checking over it every time i sit down lol. How much extra are we talking about newb? Our electrical appointment is on the 27th so unless our other mates here can give us any info as to what they have done or what they could have done then that whittled be great for us who are just about to ink and finalise our electricals then that would be great http://buildingourhumblehome.blogspot.com Land Deposit - 20.08.2016 Land Registered - 27.09.2016 Land Settlement - 07.11.2016 House Deposit - 27.11.2016 House Contracts - 16.02.2017 House Build Starts - 10.04.2017 Building with Beechwood Homes buildingourhumblehome.blogspot.com.au Re: Who is building with Beechwood 14757Apr 17, 2017 6:42 pm tapasr_Lexia4 newb Hi yes they are standard but if you want them in the 1/3 pattern then you have to pay extra so I don't think of them as standard as I personally would not have them stacked as a floor tile. Thanks for the welcome, yes we are almost at the same stage i think you have been just ahead of me so far. I have already put extra power points in each of the bedrooms as we only have one now and its not enough, plus one extra in the kitchen. Its so hard to know what to put in ive got my plan sitting on my coffee table with the extra electrical i am thinking of and just keep checking over it every time i sit down lol. How much extra are we talking about newb? Our electrical appointment is on the 27th so unless our other mates here can give us any info as to what they have done or what they could have done then that whittled be great for us who are just about to ink and finalise our electricals then that would be great http://buildingourhumblehome.blogspot.com Land Deposit - 20.08.2016 Land Registered - 27.09.2016 Land Settlement - 07.11.2016 House Deposit - 27.11.2016 House Contracts - 16.02.2017 House Build Starts - 10.04.2017 Building with Beechwood Homes Some of the other things we did at electrical Lights down the side of the house Extra circuits for power ( allows splitting later) Smoke alarm on standalone circuit (as fire fighters we go to many houses with hard wired smoke alarm and the only thing you can do is turn the light circuit off then you got no lights till they fixed) Sensor activated lights out the front facade Data points (hills home hub wasn't worth it for us) 2 & 3 way switching in certian areas Outside power points SPA circuits Tv points Phone points as well as lead in inside main power trench Extra light points Power in Re: Who is building with Beechwood 14758Apr 17, 2017 6:49 pm Does that mean two way switches aren't standard? Re: Who is building with Beechwood 14760Apr 17, 2017 7:53 pm Thanks Tom for always answerIng our question...you are a legend !!! http://buildingourhumblehome.blogspot.com Land Deposit - 20.08.2016 Land Registered - 27.09.2016 Land Settlement - 07.11.2016 House Deposit - 27.11.2016 House Contracts - 16.02.2017 House Build Starts - 10.04.2017 Building with Beechwood Homes buildingourhumblehome.blogspot.com.au Hey guys building a new place through a volume builder and just wondering if i should complain to the site supervisor as we just had plasterboard installed. Looks like… 0 11845 Elvis has left the building... The site supervisor quit after 2 month on the project. I guess he was just instructed to bark at people, but didn't like when he was… 26 21641 |
