Browse Forums Building A New House Re: Waterproofing around door jam? 2Apr 14, 2024 9:29 pm We are Expert Consultant's, and we are here to help. Re: Waterproofing around door jam? 5Apr 20, 2024 10:27 am Splashers Disgracefull waterproofing, get an independent qualified inspector ASAP. Do not allow them to start screeding or tiling Screeding is done before waterproofing Which part did you find not upto the code? Re: Waterproofing around door jam? 6Apr 20, 2024 7:04 pm Screed is installed before or after, what was not up to code? You have 4x images, door frame, The work is poorly applied rough, with no care for how it should be done, if thats the sample of the waterproofing good luck with the tiling. You need to get an inspector or contact the supplier of the waterproofing product and ask them to inspect. In brief The dry thickness looks to be to thin, The band floor/wall junction is non continuous Their doesn't appear to be a bond breaker, You have not wetstop at the door, The jambs & architraves even though they are chewed off at the base, they are still in the zone that the screed will be, therefore wicking water up the jamb/archi rotting them, finally if the tiler thinks this is good enough, then if he has a license??? he shouldn't!!! Get an inspection The application has been directly applied over timber, We are Expert Consultant's, and we are here to help. If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 8432 I have researched this topic in detail recently but for another state which has no licensing requirements at all so any handy man can waterproof any old way and not have… 1 8582 2 8770 |
