Browse Forums Building Standards; Getting It Right! 1 Aug 01, 2020 5:59 pm Hi all I finished building a deck off the rear of my house recently, and I would now like to build a roof over it. What I'm trying to work out though, is how far I can span the roof without any supports. Is anyone able to point me in the correct direction where I can find this info? What I'm trying to do is this: My deck comes out 4500mm from the house, and runs 9220mm along the back of the house. So I need the roof to span the 4500mm plus what I add to it to get the correct fall. I haven't looked into exactly what roofing I'll use, but at this stage I'm thinking it will be something clear. So is what I want to do even possible? Appreciate any help or suggestions! Thanks in advance!! Re: Building a roof over my deck 3Aug 12, 2020 8:19 pm There are timber framing tables that will answer the question. Type of timber and spacing are just two of the things that are to be considered. Re: Building a roof over my deck 4Aug 13, 2020 2:02 pm Phil of Sydney There are timber framing tables that will answer the question. Type of timber and spacing are just two of the things that are to be considered. I'm planning on purchasing the timber from Bunnings so I'll find out about the timber and then look for the framing tables. The other option is to make the roof frame out of steel, which is what I did when I built the deck. I'm assuming from your comment that framing tables are also available in this instance? I'll keep doing some searching myself but if you or anyone else has info to share, that info will be much appreciated!! Re: Building a roof over my deck 5Aug 14, 2020 10:32 am meminiau So does this mean that such a roof could be built do you think? You will need Development Application (DA) and Building Application (BA) Council Approvals meminiau I'm planning on purchasing the timber from Bunnings so I'll find out about the timber and then look for the framing tables. The timber Frame will still require compliance checks and certification for BA Here, for certified drawing use 3D Bim, work out the material Quantities and approach online suppliers for quotes. Can you please help with these deck Design Questions? I'm currently getting quotes miles cheaper than Bunnings 190 x 45mm MGP10 H2F Termite Treated Pine Blue Timber Framing - Linear Metre elsewhere Get 3 quotes meminiau The other option is to make the roof frame out of steel, which is what I did when I built the deck. I'm assuming from your comment that framing tables are also available in this instance? For steel you will require Design Capacity Tables Best to use a design engineer for certification Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Building a roof over my deck 6Aug 14, 2020 2:04 pm Thank you so much for your post!! The info you shared will be very helpful. There is one other thing... I thought that the building of it would be covered as am Exempt Development in regards to approvals; you don't think so? Coming back to this.... When installing a pressure flashing, what fixings would you use (please give a link) ? Above Pedro said nylon anchors. Anyone have a preferred… 7 11838 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20656 DIY, Home Maintenance & Repair Thanks. I was thinking of using either Extreme Joist or LOWDECK timbers for joists. Any idea what sets them apart and which… 2 13599 |
