Browse Forums Building Standards; Getting It Right! 1 May 25, 2020 10:51 pm I have recently received council approval to build a Stratco garage within 500mm of my boundary. For the approval I was told I will need to achieve a 60/60/60 fire rating on the wall adjacent to the boundary. My question is, what product and technique should I use to achieve the fire rating? My thought is to apply 16mm fyrchek inside the garage between the girt and the colorbond outer sheet. Other options for products I have found are Stramit Uniguard and Boral FireStop Anyone able to offer me advice as to whether my plan is up to scratch and if any of the 3 products is more suited? Cheers Re: Fire Rating A Garage Wall - WA 2May 26, 2020 11:26 am Hi JT714 Welcome to the forum It's going to cost you heaps to get it approved as an alternate solution Parapet and Zero lot walls should be made of brickwork, mainly due to cost and the FRLs get your engineer to certify the structure Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Fire Rating A Garage Wall - WA 3May 26, 2020 12:23 pm Cheers Chris I have been Council approved based on the Stramit Uniguard system. I figured based on that approval I can use the system that I outlined in the application. Maybe they just bumped it through due to the new legislation McGowan announced last week regarding approval of sheds and patios? Re: Fire Rating A Garage Wall - WA 4May 26, 2020 2:14 pm Great, Yep their is far too much red tape and IMO getting worse AFAIK, The Fastrack method for patios and sheds is for DA approvals You may still require a Building Application... so the fees/costs should be reduced and the time shortened? It's yet to be seen how it will unfold Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Thank you again Simeon.. I will call my certifier for that. Have a good day 4 6759 10 years ago was a different software than we use now. it has had a lot of changes over the past years. Improvments to the software and changes to how Nathers models need… 8 2426 We are tossing up between a Jarrahdale radiant wood fire (the Pioneer) and a convection wood fire (Innovator or Countryman) but cannot decide on which type of wood fire is… 0 5493 |
