Browse Forums Building Standards; Getting It Right! 1 May 04, 2020 9:32 pm Hi there, could anyone please advise if this is fine? I've asked the builder if they can fix as the heating/cooling duct is a bit squeezed here due to larger pipe above it. It might even pushed further when they do the plastering. I'm worried that there won't be enough airflow but the builder said that it was installed per the manufacturer's specifications. Am I just being exaggerated? Thanks [img:soc3o4ci]https://forum.homeone.com.au/u/94663_1588592042.png[/img:soc3o4ci] Re: Heating/Cooling duct - correct installation 2Oct 04, 2020 12:35 pm The picture is not showing but id take a photo and send it off to VBA , i had problems with my ducted heating as well, when i called a plumber to come and fix it he told i couldn't help because its none complaint, so he told me to email a complaint to vba with few photos attached, so i did a week later i got a call from the VBA telling me its not compliant and they would have the plumber to fix it they asked me who the plumber is or the builders name and i had it fixed dont let the builder tell you lie because thats all they do lie all they want is your money full stop, they have no intrest in fixing anything or any defects after hand over they just dont care. The VBA can order the installers to fix the problem or the builder. Give the VBA a call asap. DIY, Home Maintenance & Repair Hi everyone Question about Brevis gas heating undergound - was recently installed by previous owners (<1 year old) but live in a relatively large house - 4 bdr - and only… 0 5713 DIY, Home Maintenance & Repair Hi, recently a replacement rangehood was installed at my home and the installer cut holes through the double brick wall for the duct but left quite some damage to the… 0 2490 I need to replace the worn mohair seal on my sliding window, but I can't get access to the end to slide the old one out & push the new one in. I could probably rip the old… 0 5389 |
