Browse Forums Building Standards; Getting It Right! 1 Apr 16, 2020 7:54 pm Hi, I’m can’t seem to find standard, what is the tolerance for an internal and external corner for internal lining? I did a quick check of the gyprock lining and many corners are not close to 90 degrees. Pick below external corner is out 20mm over 400mm. Is this acceptable? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Wall Squareness standard? 2Apr 25, 2020 2:24 pm I can't find one either! Is the left wall long enough to be measured for bowing? The only reference I've found is from a 2002 NSW Joint select committee on the quality of buildings that notes a complaint that it is not specified. Time enough for 2 revisions by Standards Australia and plenty by the BCA. Re: Wall Squareness standard? 3Apr 25, 2020 5:58 pm You can download the guides and tolerances online, you'd be looking for wall setout and location. I think is it a defect 100%, even if it is not the tolerance get the builder to show you on the plan where it is 20mm out... Registered Building - Always happy to help where I can and simply loves the game. DM me if you need help in VIC. What we have done in a few theatres ( including my own) is run 2 layers of 13mm gyprock, but sounds insulation especially for the bass is really tricky as a lot of that… 4 2758 Thank you again Simeon.. I will call my certifier for that. Have a good day 4 6280 ok thanks - yes was wondering if that should have been listed as Option Three! 2 8086 |
