Browse Forums Building Standards; Getting It Right! 1 Jan 17, 2020 9:12 am Hi all, We have started a new build. The slab has been laid and I noticed the riser for the storm water is running down the right hand side of the block. Our block runs between two streets. We are planning to subdivide and build on the back at a later stage. With this in mind, I asked for sewage and storm water to be run down one side of the block. I've asked the builder/plumber why the storm water was run down the right hand side of the block and not the left. He has come back to me and said because the tie is on the right hand side and they would have to run storm water across the front of the block Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Is having the stormwater running down the right hand side going to cause issues with future development? It is most likely the side that would have a garage on it. Is running storm water across the front of the block more of an issue? Should I be insisting that it gets moved as per plans? Can they make a new tie so they don't need to run across the front of the block. Thanks Nigel Re: Storm water path affecting future developement 2Jan 17, 2020 9:51 am pencilhead Hi all, We have started a new build. The slab has been laid and I noticed the riser for the storm water is running down the right hand side of the block. Our block runs between two streets. We are planning to subdivide and build on the back at a later stage. With this in mind, I asked for sewage and storm water to be run down one side of the block. I've asked the builder/plumber why the storm water was run down the right hand side of the block and not the left. He has come back to me and said because the tie is on the right hand side and they would have to run storm water across the front of the block Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Is having the stormwater running down the right hand side going to cause issues with future development? It is most likely the side that would have a garage on it. Is running storm water across the front of the block more of an issue? Should I be insisting that it gets moved as per plans? Can they make a new tie so they don't need to run across the front of the block. Thanks Nigel It looks like they are try to avoid chasing grade. aka they were being lazy. The short answer is no it won't stop you from developing in the future, but the vacant lot may have to register an easement in your favour or you may need to realign the stormwater pipe in the future as part of the development (depending which local government you are in). You can you email me the plan if you want and I can review. rhett.b@dtsqld.com.au I am a town planner. Follow Our Clarendon - Double Gable, Hamptons Inspired Fairmont 35 https://forum.homeone.com.au/viewtopic.php?f=31&t=94604 Re: Storm water path affecting future developement 3Jan 18, 2020 3:43 pm Rhetti pencilhead Hi all, We have started a new build. The slab has been laid and I noticed the riser for the storm water is running down the right hand side of the block. Our block runs between two streets. We are planning to subdivide and build on the back at a later stage. With this in mind, I asked for sewage and storm water to be run down one side of the block. I've asked the builder/plumber why the storm water was run down the right hand side of the block and not the left. He has come back to me and said because the tie is on the right hand side and they would have to run storm water across the front of the block Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Is having the stormwater running down the right hand side going to cause issues with future development? It is most likely the side that would have a garage on it. Is running storm water across the front of the block more of an issue? Should I be insisting that it gets moved as per plans? Can they make a new tie so they don't need to run across the front of the block. Thanks Nigel It looks like they are try to avoid chasing grade. aka they were being lazy. The short answer is no it won't stop you from developing in the future, but the vacant lot may have to register an easement in your favour or you may need to realign the stormwater pipe in the future as part of the development (depending which local government you are in). You can you email me the plan if you want and I can review. rhett.b@dtsqld.com.au I am a town planner. Thanks for the kind offer Rhetti. I've asked for builder to relocate stormwater path as per agreed drawings. It will save any hassles later I think. Will see what he comes back with. Re: Storm water path affecting future developement 4Jan 20, 2020 7:06 am No problem. That option also works Follow Our Clarendon - Double Gable, Hamptons Inspired Fairmont 35 https://forum.homeone.com.au/viewtopic.php?f=31&t=94604 Hello I am developing 2 side by side units. Wish someone can help me on the following questions 1) Which stage should be the storm water pipe installed during the new… 0 8207 If you need to be able to access these then you may need to dig them out and cut them so you can add a socket and a riser to the required height. We normally add a… 1 7090 Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 10867 |
