Browse Forums Building Standards; Getting It Right! 1 Dec 13, 2018 4:42 pm We are currently in the handover stage of our building process. Noticed a list of brickwork issue (Bricks misalign, lint bow etc) recently and pushed my builder to fix. I noticed that brick joint line in front of my house wasn't straight. Just wondering if it is violating any standards that I could push my builder to fix? Thank you very much. Here are the pics: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ There are also misaligned mortar vertically: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Brickwork Vertical align in joint 3May 22, 2021 11:53 am When using a private inspector just be careful you are not dragged into a defamation case with a contractor instigated by your private inspector. I had a call from a lady in tears. A home inspector had not pointed out fretting mortar. Now she is up for thousands of dollars. Inspectors are quick to take your $1000 for a report. Make sure your inspector is a qualified builder so you can have their building licence confiscated. If need be you can litigate the inspector to recover your case. If you are referring to the internal brick corner, this how it should be, a bonded corner looks like this. *All in my opinion only Re: Brickwork Vertical align in joint 4May 22, 2021 11:54 am When using a private inspector just be careful you are not dragged into a defamation case with a contractor instigated by your private inspector for writing defamatory reports. I had a call from a lady in tears. A home inspector had not pointed out fretting mortar. Now she is up for thousands of dollars. Inspectors are quick to take your $1000 for a report. Make sure your inspector is a qualified builder so you can have their building licence confiscated. Unfortunately some inspectors are just vultures preying on the vulnerable. If need be you can litigate the inspector to recover your law suit costs. If you are referring to the internal brick corner, this how it should be. A bonded corner looks like this. *All in my opinion only Hi, I am planning to select San Selmo reclaimed original for the fascade of my build. I have seen many photos on line of the brick varying from a rustic to a neat finish.… 0 4752 Hi guys, I want to butt a concrete vegetable garden bed against a concrete build up of a carport. It will be a 700mm high wall about 120mm thick and I will run a 12mm rio… 0 2865 |
