Browse Forums Building Standards; Getting It Right! 1 Aug 01, 2017 11:04 pm Well I am after advice again, most of the insulation was done today, and half of the plastering. I am not happy with it. Hubby asked the brickie and he said every house he has worked on has been the same. So that's the end of it as far as he is concerned. Tired of banging my head against a brick wall. What do you think , am I being too picky? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Insulation 2Aug 02, 2017 12:10 am Grab the manufacturers installation guide, check out the link below and try to find a copy of AS3999. http://www.yourhome.gov.au/passive-desi ... stallation Re: Insulation 3Aug 02, 2017 12:14 am Here's a link to the ICANZ installation requirements. ICANZ is the industry group for insulation installation. http://icanz.org.au/wp-content/uploads/ ... 0.2016.pdf Re: Insulation 5Aug 04, 2017 11:27 pm Well I sent an email to the builder for what good it will do as they put the plaster up as soon as they finished putting the batts in. I couldn't go into the house and look at what they were doing for they could order m off site. But as soon as they drove away I had a look inside. All plastered up. Maybe I should as for the extra money back that I paid for extra 2.7 R batts instead of the 2R ones. I really doubt that they will take plasterboard down to look if there's gaps or not. I guess they will just says it's fine. Cheers Re: Insulation 9Aug 10, 2017 9:34 am I always use thermal imaging camera on my pre final inspections and more often than not I find thermal bridges where insulation is either missing or poorly fitted. Often I will also find roof leaks. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Insulation 10Aug 10, 2017 2:06 pm BTW, there are some very affordable ones out there on the market, which can be used with the smartphone: http://www.flir.com/flirone/ I am thinking of buying one for my build. Hey guys building a new place through a volume builder and just wondering if i should complain to the site supervisor as we just had plasterboard installed. Looks like… 0 11877 1000000% definitely add insulation. I have in my home and it makes a big difference minimising sound transfer. Insulation is pretty cheap and definitely worth it 2 6815 |
