Browse Forums Building Standards; Getting It Right! 1 Jan 23, 2017 1:12 pm Hi, Just like to know is it a common practice if you have bricks that runs through within the roof, that cant be seen from the outside that the builder would use standard face bricks , rather than sticking with what is used for the rest of the house. Re: standard face bricks that run through roof 2Jan 23, 2017 4:37 pm It's not unusual to use an ordinary brick where it can't be seen. If you go for a rendered finish you could find the builder has used up all the odd bricks left over from previous jobs because it won't show. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. 7 6249 I had a similar issue with my fridge not too long ago. It wasn't the same model, but the symptoms were pretty much the same: the compressor would start and then stop… 3 7516 yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7297 |
