Browse Forums Building Standards; Getting It Right! Re: Rendered EPS Pier on facade. 4Oct 10, 2016 10:20 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Rendered EPS Pier on facade. 6Oct 10, 2016 7:21 pm Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Rendered EPS Pier on facade. 7Oct 24, 2016 11:29 pm sunxiaoxuan23926 Emmz70 Can't say I've ever seen this before Sun Very odd indeed. Hope someone helps you Thanks Emma, I just came back from walk around Livingston and my estate . I can't see one house has timber or whatever board around. Sun my silly messages can't send. But I have read what you've sent!!! So angry!!!! Oh no! I would use a can of expandable foam ( there are some that will take render) then cut it back and render over the top 1 1656 I should have followed up on this thread. So, the pier foundation wasn't large enough on the side it was leaning towards, and the NBN cable went through the pier, just… 8 10722 Just be careful with building stability during construction, that is when the structure may be weakened, refer to your engineering drawings for stability methodology. 1 6176 |
