Browse Forums Building Standards; Getting It Right! 1 Aug 12, 2015 5:00 pm We have a stormwater easement at the left back of our property. We have the drain cover and understand we can't build near it in an area about 1.5 sqm. But we will probably have to build a retaining wall along the back of the property to a height of approx 900 high. Our builder said it will need to be a minimum of 1.5m from the back fence, giving us a fairly useless strip between the retaining wall and the back fence. My husband has come up with the ingenious idea (one of those 3am epithanies) to build decking over the gap with a hatch to gain access underneath giving a covered storage area for kayaks etc. What I would like to know is can we build that decking over the the easement as long as we have that segment on hinges so it can be lifted up and accessed if need be? Re: Building Decking Over Easement? 2Aug 13, 2015 3:38 pm Accessibility is one thing but the main reason for not being able to build on or within 2m is what's called "angle of repose". It's where the the bottom of the footing, if you draw a line 45degrees downward from the base must not be in the range of an easement. This is so that the pressure the footing imposes on the soil does not push force upon the easement pipe. Unfortunately it's a messy situation where you have easements involved. You could avoid this situation is you didn't dig any holes and instead used concrete feet that you can buy from Bunnings that might get you around permits etc. Maybe... Re: Building Decking Over Easement? 3Aug 14, 2015 2:01 pm In a pragmatic sense, its a personal call. Build what you like as long as it can be removed easily if the easement owner ever requires access. Bear in mind it may never happen unless the drain gets clogged. As Adam.M says, make sure what you build does not adversely affect the drain's integrity, else you will be financially liable to repair it. Hi, as per the subject. Does anyone have any recommendations for the best value decking oil (Bunning is close to where I live) for a treated pine deck? Thanks 0 13480 You should be able to encase the sewer but you will need it designed and approved and access to lot 580 to do the work 2 17887 You might be able to apply to divert the sewer at your expense. In NSW you would contact a Water services co-ordinator and they would give you advice as to whether or not… 1 17275 |
