Browse Forums Building Standards; Getting It Right! 1 Jul 16, 2014 6:43 pm Hello All, Just wanted to find out how high the weep holes should be. We just got our first home and are quite excited and happy about the same other than the issue of Weep Holes. I have bought this up with the builder, but he has tried to brush me off. In front of the entrance door there is a weep whole which is probably not even 2 cm off the concrete slab. I am a bit worried as it may be a bit of an issue during the rainy days Kindly shed some light and help me out please. Thank you. Re: Weep Holes Height ? 3Jul 16, 2014 7:13 pm Dear Liliana, Firstly let me thank you for your comment it really helps me out. The drive way is concrete slab, the exterior wall has the weep hole which is not even 2 cm off the concrete slabs in height. The weep hole is not under the concrete slab but just merely 2 cm above the concrete slab. I hope i am making sense. Re: Weep Holes Height ? 5Jul 16, 2014 9:19 pm Hi zllauh, Weep holes in walls are very common in the construction of a house. Often when it's been raining or the house 'sweats' moisture will build up behind the bricks. Weep holes enable the water to flow freely from behind the bricks to the exterior of the house so that problems such as moulding etc do not occur. If you are worried about this, it'd be best to get a Licensed Building to check it out. Hope this helps. C Re: Weep Holes Height ? 6Jul 17, 2014 12:16 am zllauh, The thread below will be of interest to you. viewtopic.php?f=3&t=60604&p=939829#p939829 Is your concern only with the one weep hole in front of the entrance door and is that area covered? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Weep Holes Height ? 7Jul 17, 2014 12:21 am ChrisieB14 If you are worried about this, it'd be best to get a Licensed Building to check it out. To ease your worries about this, it'd be best to check out a licensed building! 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Weep Holes Height ? 8Jul 17, 2014 2:48 pm Sorry, I was meant to write get a licensed >builder< to check it out. Although to thoroughly ease your worry, these in-fact are normal weep holes and cannot be covered up as they will then go against AS (Australian Standards) and BCA (Building Code of Australia). C Re: Weep Holes Height ? 9Jul 17, 2014 3:00 pm I still like the idea of checking out a licensed premise. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Weep Holes Height ? 11Jul 31, 2014 1:18 pm Indubitably. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Weep Holes Height ? 12Aug 01, 2014 2:52 pm If the weep hole is positioned correctly and is above the finished ground or paving level then their should not be an issue. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: Weep Holes Height ? 13Aug 01, 2014 7:06 pm zllauh Dear Liliana, Firstly let me thank you for your comment it really helps me out. The drive way is concrete slab, the exterior wall has the weep hole which is not even 2 cm off the concrete slabs in height. The weep hole is not under the concrete slab but just merely 2 cm above the concrete slab. I hope i am making sense. Weep holes are reqired immediately above any DPC/flashing at centres no more than 1.2m except above an opening (eg door/window) less than 1m wide or if the external brickwork is weatherproofed (most isn't). In short, there isn't much you can do about the vertical position of the weep holes but one would hope the brickie thought about the horizontal positioning of it. Ref part 3.3.4.3 of the BCA for a full explanation. it depends on the natural ground level, if they excavated their boundary wall needed to be built as a retaining wall. If you filled, which sounds like the case then you… 1 7583 I know foam has been around since the 90's and CSR started manufacturing Hebel in 1989, so it's definitely possible 5 6165 You are correct. Just read through all the ncc rules and 75mm is the minimum requirement for me. 4 11956 |
