Browse Forums Building Standards; Getting It Right! Re: No Occupancy Certificate !!BCA requirement for weep hole 2Oct 30, 2012 5:18 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: No Occupancy Certificate !!BCA requirement for weep hole 4Jan 11, 2023 9:49 pm The only solution you have to address this problem is to have the home rendered with an acrylic render like dulux acratex. As it is a acrylic system it provides a waterproof coating over the brickwork preventing water ingress through the bricks and the need for the weep holes to allow the water out. You can cement render but them you need to include a waterproofing additive and paint to complete, where the acratex does it in one. my advise, have the base coat tinted the same colour as the finish coat, this gives you better depth of colour, this is pretty much your only solution We are Expert Consultant's, and we are here to help. it depends on the natural ground level, if they excavated their boundary wall needed to be built as a retaining wall. If you filled, which sounds like the case then you… 1 7304 I know foam has been around since the 90's and CSR started manufacturing Hebel in 1989, so it's definitely possible 5 5669 You are correct. Just read through all the ncc rules and 75mm is the minimum requirement for me. 4 11522 |
