Jun 20, 2013 8:10 amSign In31 members logged in
Building Forum » Building, Renovation & Maintenance » Building Standards; Getting It Right!
Box Gutter and leaking house
New Topic Post Reply  Page 1 of 1
 [ 3 posts ]
faeros
 Post subject: Box Gutter and leaking house
PostPosted: Mar 04, 2012 3:43 pm
New Poster
New Poster
There're some serious issues with water, leakage and our box gutter, the recent downpours shows that something is not working and water is leaking into our house. The bulkhead and surrounding areas is bubbling and our new carpet is damp. I'm fearing a potential long term mould and damp issue.
Hope the builder will reply on Monday but in the mean time is there anything that I can learn about it so the problem is fix properly? Your help is most appreciated.
mgilla
 Post subject: Re: Box Gutter and leaking house
PostPosted: Mar 04, 2012 4:17 pm
Silver Member
Silver Member
I know it doesn't help now but the thing to learn is don't pick a facade with a box gutter.
As far as the problem itself, how long is a piece of string? I've seen plenty of box gutter leaks and there all different. Unfortunatly it may take a couple of go's for them to pin point the problem.
If your carpet is wet i'd suggest putting towels down and try to soak it up. then on monday when your builder gets in contact have them get a carpet dryer out to lift and dry it. Dont try and lift the carpet yourself unless you have the correct tool. If you pull it off you can pull threads.
Don't worry about any damage to the paint and plaster, once the problem if fixed the plaster will dry and can be repaired with no evidence of there ever being a problem.
Good Luck
james_d
PostPosted: Mar 05, 2012 12:33 pm
Loyal Member
Loyal Member
A large issue with box gutters is reactivity and peoples lack of understanding. Check that they have used zinc screws if it is a zinc gutter, or gal with gal. Also ask how far they flashed up the roof as driving rain can force water up there. Another issue can be the downpipes if they are undersized or blocked where does the excess water go.
 [ 3 posts ]
Users browsing this forum: No registered users and 1 guest
Read Article: Is your home Conducive to Termites? What to look for.. by Victorian House Inspections VICIs your home Conducive to Termites? What to look for..
Termites can cost you thousands of dollars in repairs and heartache.…
Read Article: Delayed Settlement:  What Are the BuyerDelayed Settlement: What Are the Buyer's Rights?
Imagine if you the settlement is delayed and you're renting. …
Read Article: What are Honeymoon Loans? by Resicert Property Inspections SAWhat are Honeymoon Loans?
Generally, you have two kinds of mortgage loans in Australia -…
Read Article: Common Issues Found in Australian Homes Part II by Resicert Property Inspections SACommon Issues Found in Australian Homes Part II
Your home may be plagued with a lot of issues. …
Read Article: DIY Checklist for House Sellers by HOUSPECT WADIY Checklist for House Sellers
One solution to improving the chances of selling your property…
Watch Video: Timber Pest Inspections by Resicert Property Inspections WATimber Pest Inspections
Resicert Timber Pest Inspections - Brilliant Inspections, Best Reports, Fast!
Watch Video: Design Services by Resicert Property Inspections WADesign Services
If you are building or renovating your house, or even getting…
Watch Video: Resicert Property Inspections Tip - Colorboond Roof  by Resicert Property Inspections WAResicert Property Inspections Tip - Colorboond Roof
What you might need to know about colourbond roof? Resicert is…
