Browse Forums Building Standards; Getting It Right! 1 May 24, 2023 2:25 am Hi guys, Engineer has provided me details for brick up retaining prior to pouring the slab, my house slab will be elevated ~700mm above natural ground level in some areas so the initial plan was to brick up and then fill/compact followed by slab. I am considering utilising deepened (drop) edge beams (illustration below) as a means to retaining the fill versus brick up retaining. Would anyone here have structural engineered drawings if they have utilised deepened edge beams in one of your developments? I would like to have a general understanding on the general thickness of the deepened edge beams (150mm?), reinforcements and general footing requirements (and rebates) prior to potentially having the engineer change the plans. Thanks! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The distance between my DEBs varies from 4.1m at the narrowest to 8.1m at the widest. 5 27787 Hello everyone, After some suggestions and ideas about how to put a concrete path around the drop edge beam area on our new build. We are required to have a concrete path… 0 13316 I would like to build our new house with the rear section approx 1 metre out of the ground, I don't particularly like to go bearers and joists so concrete slab all the way… 0 3988 |
