Browse Forums Building Standards; Getting It Right! 1 Jul 20, 2022 9:02 pm Hey Guys, I have been playing around with some ideas before I engage a designer to prepare full construction drawings and specifications suitable for an owner-builder. I want to use the garage roof as a balcony but this balcony level is ~480mm above the first floor level so I'm going to need a small flight of stairs to get up there. I have been looking at https://ncc.abcb.gov.au/editions/2019-a ... 1-stairway but it doesn't include my exact scenario where I have 3 winders to get to up the balcony. The first blue winder is at the same level as the first floor level. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Anybody with a good working knowledge of NCC 3.9.1 got an opinion if my proposed flight of stairs is compliant. Cheers Marbles Re: Stairs without landing 2Jul 22, 2022 9:20 pm That is an unusual design, it would be weird standing on a winder to open a door with a door handle either too low or too high. It might be compliant as the door opens inwards. Winders are really a last resort I think. Can you put the steps in the patio area , it would encroach in the garage ceiling but not be too ugly, otherwise can the stairs be on the other side of the door?, in the house, both would be more common and work better, good luck Re: Stairs without landing 3Jul 23, 2022 9:02 am Pulse That is an unusual design, ... Yes, unusual and probably undesirable but there are a few constraints in play. Thinking through the options its probably best I make some other concessions to get a better outcome. I am looking to design an entry door to a lower ground basement that has 2200mm between the external entry height to FFL of the ground floor. This door will provide an… 0 12882 Got my stairs designed like this with 250mm Gap marked below. Gap is bec of 2 steps added between two landing area… 0 5059 Move your linen into laundry and access laundry from your present linen space 1 8494 |
