Browse Forums Building Standards; Getting It Right! 1 Jan 30, 2023 9:39 am Hi - How concerned would you be if the house frame is not plumb / square ? As you can see in the photo, the door frame from which sliding doors will be hung, and which forms the outer perimeter of the house frame is not square, and slowly deviates from the frame above. Just hoping I can get some advice if this is a "cosmetic" concern and can be trued up with gyprock lining etc? if it is a concern, what would you expect the corrective action would be to rectify? Can they "reseat" this part of the frame? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: House frame not plumb! 2Jan 30, 2023 10:15 am The sliding doors will be substantially smaller than the frame and will be packed out to fit. Its likely the look when all is done and dusted will be square. The question is whether this defect has any structural significance. Ask your inspector and whether they can explain it so you have the right ammo to go at the builder with. Inspectors will raise all their identified defects and use the same language for all of them, so sometimes its hard to determine what is material and what isn't. This is 100% true. You can not hang anything on steel frames. very frustrating 8 10345 Hi, We have a single story MacDonald Jones house, on a waffle pod slab with steel frame. Are we able to build a second story extension? Other info is we are 900mm from… 0 9233 Its the flashing and is normal. Some builders cover them up others just leave them handing. You can cover it up with an aluminium bracket or ask the builder. 7 11774 |
