Browse Forums Building Standards; Getting It Right! 1 Jul 09, 2021 11:50 am Thanks in advance for any advice. I am currently building with a volume builder, they have inserted aluminium storm moulds above my double glazed windows measuring 6.2cm (almost a full brick). Apart from looking aesthetically ordinary, I am also concerned that my thermal benefits of having and paying for double glazed windows will be significantly reduced? 1) Are these storm moulds (especially this size) normal practice 2) Does anyone know of the BCA code for this? I can't find anything? Thanks in advance Re: Window storm moulds 2Jul 09, 2021 11:59 am AJK1 Thanks in advance for any advice. I am currently building with a volume builder, they have inserted aluminium storm moulds above my double glazed windows measuring 6.2cm (almost a full brick). Apart from looking aesthetically ordinary, I am also concerned that my thermal benefits of having and paying for double glazed windows will be significantly reduced? 1) Are these storm moulds (especially this size) normal practice 2) Does anyone know of the BCA code for this? I can't find anything? Thanks in advance Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hello I am developing 2 side by side units. Wish someone can help me on the following questions 1) Which stage should be the storm water pipe installed during the new… 0 8005 If you need to be able to access these then you may need to dig them out and cut them so you can add a socket and a riser to the required height. We normally add a… 1 6977 Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 10738 |
