Browse Forums Building Standards; Getting It Right! 1 May 01, 2021 6:55 pm Hi there, Thanks in advance. Just moved in to a new house and there is a very noticeable squeak on the 1st floor. The house is made of wooden frame. Floor is laminate board but the squeak is not from the laminate board but instead sounds like its coming from the joist. Is this something I should worry about (structurally) or rather not a critical issue but just more of an annoying factor (squeaky noise)? Thanks Re: squeaky floor joist 2May 01, 2021 7:02 pm volmix Hi there, Thanks in advance. Just moved in to a new house and there is a very noticeable squeak on the 1st floor. The house is made of wooden frame. Floor is laminate board but the squeak is not from the laminate board but instead sounds like its coming from the joist. Is this something I should worry about (structurally) or rather not a critical issue but just more of an annoying factor (squeaky noise)? Thanks Forgot to mention, house is about 3 years old only.. Re: squeaky floor joist 4May 01, 2021 8:19 pm Berek It’s a building defect. Is it your house? Won’t affect the structural integrity at all but will be annoying as all.... Thanks Berek, appreciate the advice. It is my house - I guess as long as its not a structural issue, even though its annoying, I can sleep a lot better at night lol. Re: squeaky floor joist 6May 02, 2021 8:14 pm Thanks Berek, appreciate the help. Would you happen to have the link to that big thread you mentioned? I tried to search but couldnt find it. Thanks! Also, I am in Qld, so cannot claim on builders warranty unless it is structural. I may still give the builder a call to see if he wants to come take a look. Thanks! Assuming you've modelled the TB8, TB10, TB12, TB2 & J1 joists/LVLs there, it appears as per drawing to me. There maybe should be an additional J1 between TB10 and T12 if… 3 32527 1 10489 Seconded; we just used these last weekend to build a small deck. They worked perfectly as we have bluestone in the area where we wanted to build so digging down was not… 8 9551 |
