Browse Forums Building Standards; Getting It Right! 1 Jan 25, 2021 9:23 pm Re: Fencing issues!! Help Required!!! 3Jan 26, 2021 8:02 am aussieta what are council rules in your area is it main road or side street distance to nearest intersection other houses in your street havent given us much information to work with The road marked is the primary road and council rules are that you cant have a fence over 1.2 meters in the setback area/past the building line. However we dont have a backyarf either and wanted to cover up the area where we hang clothes and other private items. Re: Fencing issues!! Help Required!!! 4Jan 26, 2021 8:06 am council rules are that you cant have a fence over 1.2 meters in the setback there is your answer you will need to create a wing fence from the front of your house to the side boundary maintaining the same distance from the front boundary effectively cutting your yard in half Re: Fencing issues!! Help Required!!! 5Jan 26, 2021 8:15 am aussieta council rules are that you cant have a fence over 1.2 meters in the setback there is your answer you will need to create a wing fence from the front of your house to the side boundary maintaining the same distance from the front boundary effectively cutting your yard in half Could you send an example of a wing fence please? Thank you I know foam has been around since the 90's and CSR started manufacturing Hebel in 1989, so it's definitely possible 5 6160 Minimum overhang into gutter must be 50mm, turn down tool should not split the sheet. it seems wrong tool for the profile was used, the flashing cannot slope back. Rib… 2 2466 1 3472 |
