Hi everyone, my first time dealing with steel frame it's prefabricated but can't find any info about tie down,
Do they still need continuous rod tie down floor to truss ,if so any idea about spacing
Browse Forums Building Standards; Getting It Right! Re: Continuous tie down 2Jan 14, 2021 8:37 pm Is it a house, shed or patio What's the wind rating N1, N2 etc on the site It should be on your DA form? hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Continuous tie down 3Jan 15, 2021 6:10 am Thanks for the response, New house, raised floor , wind N3, the engineer who designed the floor specified tie down from steel bearer to bottom plate of steel frame, 1500mm spacing, I couldn't find any details in the permit Re: Continuous tie down 4Jan 15, 2021 7:40 am You will require an engineers certificate from the truss manufacturer as well The tie down should be continuous from the footings to the truss you also require shear wall certified design OT the engineer often only gets asked and paid to design one aspect of the structure, eg Footings, If they don't get paid they don't look at the rest of the structure, ie the walls and roof trusses. If they are manufactured they should come with a structural certificate certified by the manufacturers engineers It's Up the the Building surveyor and council to make sure all documents are complete and correct How do you know if its been built correctly if you don't have all the documentation, non compliance can also potentially void any possible future insurance claims hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Continuous tie down 5Jan 15, 2021 8:37 am I bought the frame through a builder, the manufacturer sent me form 15 and all fixing details and tie down ,, all there but couldn't find any details about tie down rods, will go through the details again but i think I will try to contact engineer to check on spacing I'm on that journey. I had to demolish a single story brick veneer on concrete raft slab about 220 sq meters for about $19k. They took forever to get a permit and I… 2 1982 |
