Browse Forums Building Standards; Getting It Right! 1 Oct 12, 2020 8:00 am Hi, We are building our concrete sleeper retaining wall. I noticed that there are quite a few sections where there are gaps at the bottom. To level the bottom sleepers, the landscaper drilled bolts at the bottom of the posts and inserted window packers below the bolt to the concrete footing. I am worried that the piers are taking much more stress than it should have and the sleepers might bow down in the middle. If this is not the right way to do it, is there a standard somewhere that I can refer the landscaper to? Can I pack something at the bottom of the sleepers to support them? Thanks in advance Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: What to use to pack concrete sleeper gaps at the bottom? 3Oct 12, 2020 8:52 pm Pulse no problems, they won’t bow as they are made of reinforced concrete, fill the gap with some dirt if needed Thank you! Yes, I might need to fill this gap. It could possible provide path for water to run through. Brass fly wire, you will need to cut it, shape it and jam it into brick slots 1 7745 Building Standards; Getting It Right! Hi, sorry if this is the wrong place - I’m new to the property/building journey (trying to buy my first home) so not sure where/who to go with these sorts of… 0 19553 Sorry I missed this, simply put this is a pathetic job, and as it stands it is non-compliant... I think the worst part is not in the quality of the workmanship so much… 5 7362 |
