Browse Forums Building Standards; Getting It Right! 1 Sep 19, 2020 9:59 pm Hi, I am nearing my 90-day defect warranty inspection. While walking around the house, I noticed my weep holes under the window looks like there is a plastic membrane under it but it only covers half the brick from front to back. Not exactly sure what the membrane is called. However, forward to that, I usually see A viid from the brick under it. Is this normal or poor installation? So when it rains, this weep holes are effectively funnelling water to the brick voids? [img:2bybqaqf]https://forum.homeone.com.au/u/92632_1600516931.jpeg[/img:2bybqaqf] Brick voids under Weep holes (Window sill) 2Sep 20, 2020 6:32 am Hi, I am nearing my 90-day defect warranty inspection. While walking around the house, I noticed my weep holes under the window sill looks like there is a plastic membrane under it but it only covers half the brick from front to back. Not exactly sure what the membrane is called. However, forward to that, I usually see A void from the brick under it (no mortar). Is this normal or poor installation? So when it rains, this weep holes are effectively funnelling water to the brick voids? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ it depends on the natural ground level, if they excavated their boundary wall needed to be built as a retaining wall. If you filled, which sounds like the case then you… 1 7582 I know foam has been around since the 90's and CSR started manufacturing Hebel in 1989, so it's definitely possible 5 6163 You are correct. Just read through all the ncc rules and 75mm is the minimum requirement for me. 4 11954 |
