Browse Forums Building Standards; Getting It Right! Re: perpends and mortar on the inside face 21Jun 02, 2015 8:27 pm What you are seeing is example of one sided flick jointing. Flick jointing is sloppy bricklaying practice where bricklayer trowels on a little mortar to front and back of the brick end. When laid and pressed to form perpend, front and back appear OK but hide a hollow in the middle of brick (you can see it only on top course. One sided flick only fills front of perpend and middle and rear are hollow. It is because of flick jointing you get blow holes when washed with acid because joints are not full of mortar. Face brick wall is not load bearing but it still needs to be structurally adequate particularly in the matter of embedment of brick ties that tie brickwork back to the frame. Now imagine two storey brick panel with hollow perps and sloppy beds and a gust of wind. Now imagine it falling on people or kids, who is going to be running for cover "It wasn't my fault"? It's not OK Guide to Standards and Tolerances 2015 3.09 Voids and holes in mortar Voids and holes in mortar in masonry walls, with the exception of weepholes and vents, are defective if they are visible from a normal viewing position. In answer to mgillla, one of my clients is aircraft maintenance engineer and he told me that if they maintained aeroplanes the way we build we would have crashes every day. I don't need to be fishing for work, I am in a position where sloppy builders create demand for my (and other inspectors) services Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: perpends and mortar on the inside face 23Jun 12, 2015 9:04 pm Happy to report that after engaging Porter Davis' group building manager and him personally attending site to inspect the bricks and sisalation yesterday, that I got a call late this afternoon from the regional construction manager to inform me that all bricks and sisalation will be coming down and will be redone from scratch. It's going to be a lot of work as the house is now fully bricked and the garage construction has already started; Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ It's also going to mean additional delays, but we're very happy knowing that it'll now be done properly and that we'll not be forced to accept a house that isn't up to standard. Thanks for everyone's help. Re: perpends and mortar on the inside face 24Jun 12, 2015 9:21 pm Dojrude,Good to hear and thanks for the up-date Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: perpends and mortar on the inside face 26Jun 13, 2015 7:06 am Well done dojrude! You just proved it is possible to get builder to demolish and rebuild defective work with a bit of right advice. Promise to rebuild does not make it over yet, I would be keeping meticulous file with photos and you should have rebuild closely watched because I have seen some that were no better than originals. Good luck Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: perpends and mortar on the inside face 28Jun 14, 2015 10:49 am Quote: What you are seeing is example of one sided flick jointing. I've yet to see a brickie lay bricks other than flick jointing ( both sides ). I think the difference is in how much mud they apply to the external corners of the brick so when they tap the brick into place the mortar squeezes into the majority of the perpend space. Good result too dojrude! Stewie Recently I moved to a 30 year old house and found within few months there are small brown nests in the brick mortar and few small round holes in few places of brick… 0 24465 Hi, I am planning to select San Selmo reclaimed original for the fascade of my build. I have seen many photos on line of the brick varying from a rustic to a neat finish.… 0 4850 Building Standards; Getting It Right! Hi, sorry if this is the wrong place - I’m new to the property/building journey (trying to buy my first home) so not sure where/who to go with these sorts of… 0 20140 |
