Browse Forums Building Standards; Getting It Right! Re: Downpipe compliance question- rainwater tank 2Aug 28, 2017 2:06 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Downpipe compliance question- rainwater tank 4Aug 29, 2017 1:54 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Downpipe compliance question- rainwater tank 7Sep 03, 2017 10:01 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Downpipe compliance question- rainwater tank 9Sep 13, 2017 9:25 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Downpipe compliance question- rainwater tank 11Nov 07, 2018 6:53 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Downpipe compliance question- rainwater tank 13Nov 08, 2018 6:04 am The requirement and regulations for rainwater tanks varies between states and even regions within States. Your situation depends on where you live and sometimes your council wikll have over-rides. There is not a one all-encompassing rule and not all States require water tanks on new homes. The 2,000 L tank servicing a minimum 50 sq m roof catchment area is a Victorian 6 star requirement (are you in Victoria?) but a tank is not required if you specify a gas boosted solar HWS or when the property is connected to recycled water...water that you are charged for. "Roof catchment" is deemed to be the roof area as looked at as a flat plan area but factored for the slope by using a multiplier found in AS/NZS 3500.3 which allows for wind driven rain. For example, the common 22.5 degree roof slope is factored as 1.21 which would give a plan area of 40 sq m draining to one downpipe a factored or roof catchment area of 48.4 sq m. In this situation, two downpipes would be required. Note that a standard Victorian slotted 115mm quad gutter would not be compliant to drain a 48.4 sq m roof catchment area in any case. NSW is bound to BASIX. South Australia has a tiny 1,000 L mininum tank capacity requirement and they don't allow the use of manual switching devices! This variation is found in the NCC. The tank size is also dictated by local council rules which may include a detention requirement. In these cases, the tanks can be very large. Different State variations are found in the NCC but local councils can override national regulations and these mandates do not appear in the NCC. Your builder should know the local council overrides if any. The BCC minimum roof area harvested mandate I mentioned earlier is one example. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Grate, thank you! RexChan if thats the reason i could sleep well without thinking about additional cost. But 1st i'll need to read about NRV cleaning/replaing stuff. I… 7 31911 There is a difference in meaning between "available" and "connected" but the whole thing is ridiculous as the Victorian regulations bizzarely preference gas, not… 3 278 |
