Browse Forums Feng Shui 1 Aug 26, 2019 11:46 pm Any suggestions or advice on my proposed floorplan? We've intentionally brought out the bathroom wall to avoid the front door directly leading to the back... But not sure if it's affective and to be honest aesthetically we prefer the straight hall way that leads to the back open plan space. What are people thoughts? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Feng Shui tips/advice on my proposed floorplan? 2Aug 27, 2019 11:39 am My house has a long corridor from front door into the lounge. It feels like a hotel corridor with room doors. The tunnel vision provided by linen cabinet and bathroom will provide some reprive and thats recommended. Get a high window in Bed 2 on wall opposite the door. The current windows have a porch view and that will mean that those remain closed most of the time (privacy). The high window on the other wall will help.. You can extend wardrobe in Bed 2 by aligning the door a bit. A high window above bed in Master Bed could also be useful. Consider a glass sliding exterior door for laundry. These door shut much better and allow light inside to help with drying. Re: Feng Shui tips/advice on my proposed floorplan? 5Aug 28, 2019 10:33 pm Hi thanks for your reply. There is a robe for bedroom 3. They just accidentally left it off the drawing. Do you mean that the fridge and oven will struggle from an electrical circuit point of view or did you mean from a Feng Shui point of view? Re: Feng Shui tips/advice on my proposed floorplan? 6Aug 28, 2019 10:34 pm Hi thanks for your reply. There is a robe for bedroom 3. They just accidentally left it off the drawing. Do you mean that the fridge and oven will struggle from an electrical circuit point of view or did you mean from a Feng Shui point of view? Re: Feng Shui tips/advice on my proposed floorplan? 7Aug 29, 2019 6:22 am fridge works by transferring internal heat to its outside skin if it is next to a heat source (oven) it will not be efficient in giving off that heat many new houses are built this way if you google fridge feng shui it says position fridge away from oven Do you really want to accommodate the window? What is on the outside of the window? Do you want to be able to see your towels from outside? I would blank the window from… 2 9367 2 6482 Just be careful with building stability during construction, that is when the structure may be weakened, refer to your engineering drawings for stability methodology. 1 7306 |
