Browse Forums Feng Shui Re: Seeing Straight through house 9Aug 25, 2015 7:01 pm I am no expert although What you can do is alter either the exit or the entrance. Change the door position. Re: Seeing Straight through house 12Apr 28, 2017 10:12 am goody59 Who really cares about Feng Shui? If you want to have that look through from front to back just do it. In my humble opinion atleast. According to our feng shui Consultant (now he is actually known as a Master, so knows his stuff) the problem with straight through is that the chi is not retained for any time at all. Therefore it is not auspicious for the occupants, especially in terms of money. Re: Seeing Straight through house 13Jun 02, 2017 7:29 am I also think it has something to do with the flow of the energy that usually starts from the front door. So if you front door directly leads to the backyard, then the energy does not stay within the house itself. I think you could counter the situation by placing decorative in the passageway to capture the energy in phases. Another alternative would be to place an ornament or structure in your backyard so the energy will flow around your backyard instead of leaving the house completely. There is evidence of water on the head reveals. That could have happened during the build, or may be happening currently. There are water stains above a couple of windows… 2 3830 yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7320 Hi When it rains in a particular direction water comes through the security door. It hits the main door and the bottom swells and jams. There is already a cover over the… 0 38444 |
