Browse Forums Windows & Doors 1 Aug 06, 2020 3:48 pm Re: Which seal to use? 2Aug 10, 2020 2:57 pm Hi I am unsure of what you are trying to achieve. You window looks as though it has a sill flap which appears to be closely fitted. Whatever you do, do not cover the drainage holes in the sill. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Which seal to use? 3Aug 10, 2020 3:00 pm ECOECO Hi I am unsure of what you are trying to achieve. You window looks as though it has a sill flap which appears to be closely fitted. Whatever you do, do not cover the drainage holes in the sill. Ed Re: Which seal to use? 4Aug 10, 2020 3:05 pm Can you take photos in a higher definition so I can enlarge them. Right along the sill would be best. Show me on the pics what you are trying to cover. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Which seal to use? 6Aug 10, 2020 3:14 pm I understand. No sill flap, are these new windows? Are the drain holes under the sill or at the front of the sill? The window could have been set further forward to close the gap to the bricks - is this an option? "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Which seal to use? 7Aug 10, 2020 3:16 pm ECOECO I understand. No sill flap, are these new windows? Are the drain holes under the sill or at the front of the sill? The window could have been set further forward to close the gap to the bricks - is this an option? Re: Which seal to use? 8Aug 10, 2020 3:30 pm So the job is to close the gap from bricks to sill. To be honest, the windows don't suit the opening, and should have been measured to set them further forward particularly because this window has an offset reveal. Plus an inline reveal would have left no gap. Let me think and come back. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Which seal to use? 10Aug 12, 2020 3:25 pm In short, there would be no gap, except for say 5mm planned for caulking. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Which seal to use? 11Aug 12, 2020 4:45 pm These were new windows retrofitted in an old house. There is render below the reveals which means the outer bricks are lower than the inner bricks thus the gaps. And older brick works weren't perfect either. Re: Which seal to use? 12Aug 13, 2020 11:49 am I know the problem. We install our replacement windows in lots of different building-in situations. This could have been done differently with a better result. The fix will be a compromise. Maybe an aluminium box section all round would look like it's a single product rather than a fix-up. Then caulk the section especially at the sill, but be careful not to cover the drain holes. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 I need to replace the worn mohair seal on my sliding window, but I can't get access to the end to slide the old one out & push the new one in. I could probably rip the old… 0 5685 4 15100 If what you describe is correct then the brick wall has been dry lined with villa board. That basically means that the villa board is glued to the brick wall with… 3 8886 |
