Browse Forums Windows & Doors 1 Mar 21, 2020 2:42 pm Hoping you can help me I’m in a building code loop. We are CDC. I feel like there must be a solution but I’m missing it. Sorry please bare with me with details below! Upstairs kids bedrooms on side boundary- windows. Height of room is 2450. I think top of window needs to be at 2250. Child protection: Under 1700 high must have max 12.5cm gap. So either opening is above 1700 or you have fixed lock on the gap. I want louvres which only have 10cm opening so I don’t see this as a huge constraint. Privacy: anything below 1500 must have screen (so dense no point having window I think) or obscure glass. So if I want a window of at least 1000 high I would need to have frosted. Or I could do frosted fixed and then on top have opening windows - louvre or awning. What would you do? Solutions I’m missing?! Builder wants to do a 600 high, 2400 wide window, at the 1700 line. I feel like this is not high enough! Re: Upstairs bedroom windows - solutions please 2Mar 21, 2020 4:04 pm Just on the child protection issue - we have almost floor to ceiling louvres on the upper floor. It wasn’t sufficient that the louvres have only a 10cm gap, we had to get special louvres that lock the individual blades in their frame so they can’t be removed and the gap made bigger. These types of louvres are significantly more expensive! Just something to consider if this applies to you legally where you’re building. We are in NW Sydney. Re: Upstairs bedroom windows - solutions please 3Mar 25, 2020 2:18 pm Child protection: Under 1700 high must have max 12.5cm gap. So either opening is above 1700 or you have fixed lock on the gap. I want louvres which only have 10cm opening so I don’t see this as a huge constraint. I see Hillsbuilds had a problem with louvres meeting the standard. This surprises me as a child could not remove a blade with one hand, and the standard allows a window to open wider than 125mm if it has 2 catches which need 2 hand operation. So I would challenge that... Privacy: anything below 1500 must have screen (so dense no point having window I think) or obscure glass. The standard is obscure or screened up to 1700 above finished floor level. So if I want a window of at least 1000 high I would need to have frosted. Or I could do frosted fixed and then on top have opening windows - louvre or awning. What would you do? Solutions I’m missing?! I recommend a window with a transom at 1700 FFL with obscure below that and an opening sash in clear above that. Builder wants to do a 600 high, 2400 wide window, at the 1700 line. I feel like this is not high enough! What do you want? "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 I have a home gym at home. It weights 150KG including the weight stack. I'm a big boy, around 150KG myself. I was thinking about moving it up stairs to the second… 0 6643 In the end, two pieces of treated timber (20mm thick) were bolted onto the joists and planed when there was too much sticking out. Passed inspection. 13 8331 I would find out how deep your clay base is and depending on the depth install a cut off drain which is more than a normal agi drain. Where the neighbouring walls is… 2 3423 |
