Browse Forums Windows & Doors 1 Jan 15, 2019 10:43 am Hi - we have recently moved into an older house, and i'm hoping to improve the timber awning windows (we have a lot of them). Does anyone have a suggestion on how to screen them with a fly screen? i thought i could retrofit a winder system that sits outside the frame ? I'm not sure what would work best Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Screen and secure older timber awning style windows 2Jan 15, 2019 11:07 am lukeb0030 Hi - we have recently moved into an older house, and i'm hoping to improve the timber awning windows (we have a lot of them). Does anyone have a suggestion on how to screen them with a fly screen? i thought i could retrofit a winder system that sits outside the frame ? I'm not sure what would work best You could retrofit winders, but that would limit the opening size and thus limit airflow. Alternatively, if accessing the window latch after screening was your concern, you could install magnetic or retractable screens. The latter would, however, be relatively expensive. Re: Screen and secure older timber awning style windows 4Jan 15, 2019 12:16 pm lukeb0030 I looked into the retractable screens, they were roughly quoted at $550 per window which is going to be too expensive for ~20 windows Magnetic might be better then. Re: Screen and secure older timber awning style windows 5Jan 15, 2019 3:02 pm arcadelt lukeb0030 I looked into the retractable screens, they were roughly quoted at $550 per window which is going to be too expensive for ~20 windows Magnetic might be better then. Any flyscreen supplier can fit flyscreens around the chainwinder... so I would go with that. Price say $40-$50 each. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Screen and secure older timber awning style windows 6Jan 15, 2019 4:06 pm ECOECO Any flyscreen supplier can fit flyscreens around the chainwinder... so I would go with that. Price say $40-$50 each. Yes, but he would have to fit the chain winders too, with additional cost and time expended. The reason I mentioned the solutions I did is because they avoid that. Re: Screen and secure older timber awning style windows 7Jan 16, 2019 8:43 am arcadelt ECOECO Any flyscreen supplier can fit flyscreens around the chainwinder... so I would go with that. Price say $40-$50 each. Yes, but he would have to fit the chain winders too, with additional cost and time expended. The reason I mentioned the solutions I did is because they avoid that. But your solutions also avoid controlling the sash when it is windy, restricting the opening to comply with AS1288. And with a chainwinder, you can lock the window open or closed. It is what Luke suggested and I am offering a solution to him. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 I had an old shower unit that broke on me and when I took it off, there were only 2 water pipes, instead of the normal 2 water pipes and a shower head pipe. S o I… 0 37307 You have no photo with your post. Best I can say is to remove an A&L flyscreen don't be afraid to distort the frame almost like a trapezium. It doesn't take a lot of… 1 7456 4 15029 |
