Browse Forums Windows & Doors 1 Oct 21, 2016 11:57 pm The builder has ordered a 2340 x1200 sliding door for a cavity of the same size. Sounds ok... However. .... This door is for a cinema room that has a step down of 180mm. The door is to be mounted on the inside wall of the cinema room. It is big and heavy! Guessing this door can't be suspended in mid-air! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Display home without Step, showing door and mounting Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We also have a shadow line bulk built right down to the top of the doorframe Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ What can we do to solve this without compromising the aesthetics of the foyer? I'm thinkin they might need to get a door custom made to enable it to sit on the floor in the media C U S T O M. C O R A L. B R O N T E. 43 http://forum.homeone.com.au/viewtopic.php?t=79581 M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Media room door doesn't fit 2Oct 22, 2016 7:22 am Barn doors are suspended on rollers from the top track. I don't see why they wouldn't be able to do it. Building the Denver by Metricon on acreage Land settlement: 24/8/15 Contracts: 8/7/16 Finance approved: 5/8/16 Council approval.....? viewtopic.php?f=31&t=79213 Re: Media room door doesn't fit 3Oct 22, 2016 7:45 am bubblynutter Barn doors are suspended on rollers from the top track. I don't see why they wouldn't be able to do it. Does that track hang off the ceiling though? We have that bulkhead and I don't know if it can take that weight. Thanks for replying by the way C U S T O M. C O R A L. B R O N T E. 43 http://forum.homeone.com.au/viewtopic.php?t=79581 M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Media room door doesn't fit 4Oct 22, 2016 8:43 am Building the Denver by Metricon on acreage Land settlement: 24/8/15 Contracts: 8/7/16 Finance approved: 5/8/16 Council approval.....? viewtopic.php?f=31&t=79213 Re: Media room door doesn't fit 5Oct 22, 2016 8:45 am Ahh yes I get you. But the problem with mine is the door will not be on the floor like yours. If it was, it would have to measure 2340 + 180 for the stepped down slab C U S T O M. C O R A L. B R O N T E. 43 http://forum.homeone.com.au/viewtopic.php?t=79581 M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Media room door doesn't fit 6Oct 22, 2016 8:53 am They don't need to be on the floor to work though, not unless you want it to be. If it's mounted on the inside of the media room, it will look aesthetically fine from the foyer. You would only see a gap from the bottom of the door to the floor from inside the media room, and I think that's something that would only bother you initially, not once you've lived there a while. Building the Denver by Metricon on acreage Land settlement: 24/8/15 Contracts: 8/7/16 Finance approved: 5/8/16 Council approval.....? viewtopic.php?f=31&t=79213 Re: Media room door doesn't fit 7Dec 21, 2016 11:35 am Most door places like home doors will do custom sizes for a bit extra Hello everyone Please advice me how can I install mesh security window or we cab say mesh flyscreen inside while the pvc plantation shutters are already installed? Is… 0 11591 This is the current bathroom with a european laundry. Overall internal dimensions are 3.69 wide and 3.65m deep, including the footprint of the laundry. There is a toilet… 0 10337 Thanks for much mate. I see that you do cabinets before flooring. For timber flooring, for most parts it's fine because it's got base plates, and for door jabs you can… 7 11487 |
