Hi,
I only learnt recently that windows can have different thickness of glass. The most common thicknesses I've seen are 4, 5 and 6mm. My question is, the standard seems to be 4mm. Does it make sense to upgrade to 5mm or even 6mm?
Thanks
Browse Forums Windows & Doors 1 Aug 08, 2016 12:17 am Hi, I only learnt recently that windows can have different thickness of glass. The most common thicknesses I've seen are 4, 5 and 6mm. My question is, the standard seems to be 4mm. Does it make sense to upgrade to 5mm or even 6mm? Thanks Re: Thickness of glass 2Aug 08, 2016 8:24 am Thicker glass is less likely to break if it gets a knock,and will make a small difference in the noise coming through the window. (See http://anewhouse.com.au/2015/11/reducin ... h-windows/) The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Thickness of glass 3Aug 08, 2016 10:32 am Leaving out sound leakage through walls and ceilings, and around a window frame. Thicker glass is the most effective way of reducing noise through a window. It can be improved by using double glazing with differing thicknesses, and using laminated glass... but the major improvement is total glass thickness. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Need to remove glass panel out of concrete without wrecking the glass to get the spa room in, any recommendations on how to do that. Thank you 0 39593 What do you need them to withstand? If it's normal wear and tear, then either will do, if you want resistance to ingress then laminated would be the favourite, but only… 1 12835 |
