Browse Forums Windows & Doors 1 Apr 04, 2016 7:42 am Hi we 'had' decided on everything and signed off on our plans. But now the husband is wondering if we should have put a sliding door in our master bedroom instead of double Windows. I am spent as far as decisions go so I was wondering if anyone has some advice on this. There will be a patio off the master so rain isn't a problem just wondering about dust getting in. Here is our house ... It is bed 1 any thoughts would be appreciated thanks Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ viewtopic.php?f=31&t=82619 Re: Sliding door or window in master bedroom 4Apr 04, 2016 6:31 pm I did it for one house that had a good view onto a private garden. . . it worked well. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Sliding door or window in master bedroom 6Apr 04, 2016 9:31 pm Next silly question which way do you have the door opening , screen closer to you bed or closer to the ensuite ? Thankyou viewtopic.php?f=31&t=82619 Re: Sliding door or window in master bedroom 7Apr 04, 2016 9:54 pm Awesome plan I would have it sliding towards the wardrobe if it was my home. Re: Sliding door or window in master bedroom 8Apr 04, 2016 10:07 pm I would have the opening end closest to the ensuite end. That way, you don't have to walk around the bed to get out the door. Re: Sliding door or window in master bedroom 9Apr 04, 2016 10:57 pm rocketship I would have the opening end closest to the ensuite end. That way, you don't have to walk around the bed to get out the door. Re: Sliding door or window in master bedroom 11Apr 28, 2016 4:01 pm I will definitely use the sliding door. Re: Sliding door or window in master bedroom 13May 04, 2016 9:12 pm For master bedroom you can use in built mirror sliding steel doors which save your space and look beautiful as well. http://www.tradeindia.com/manufacturers/steel-doors.html Re: Sliding door or window in master bedroom 14May 07, 2016 1:33 pm I'm wondering how you'll place furniture in the bedroom. Every wall has a door on it. It's hard to see dimensions, but is there a wall with enough room to fit the bed and bedside tables? If the only possibility is the wall with the window, I'd leave it a window so the bed could go underneath. Re: Sliding door or window in master bedroom 15May 07, 2016 10:20 pm Frye I'm wondering how you'll place furniture in the bedroom. Every wall has a door on it. It's hard to see dimensions, but is there a wall with enough room to fit the bed and bedside tables? If the only possibility is the wall with the window, I'd leave it a window so the bed could go underneath. Thankyou, there is enough room one the left and opposite the window walls for a bed and bedside tables I’m in a similar position except I’m after sliding 3 stacking doors. I am on a second-story apartment of which the balcony would not adequately fit any bi-fold or… 5 16762 DIY, Home Maintenance & Repair Thanks Chippy . Did also see a YouTube video before. Removed them . Thanks again for the advice. 2 14183 |
