Browse Forums Windows & Doors 1 Dec 07, 2014 10:40 pm Hi, I am an Owner builder and have had new aluminium sliding doors installed by the carpenter. Under the track at the bottom he has chocked it in 3 places with bits of scrap timber say 6mm thick off of the slab. My question is: What should go under the sliding door track for a permanent solution? Looks like the packers under the tracks are a temporary solution. Should I use the non-shrinkable structural grout? Please advise. Thanks Andrew Re: New Sliding Door Installation 2Dec 08, 2014 6:39 am How deep is it LM ? Could you fill with ply etc and then "grout" ? Re: New Sliding Door Installation 4Dec 14, 2014 5:21 pm 4200 long. That is a very heavy door. On my build I used plastic builders wedges to provide temporary support. I then installed strong mortar under the sliding doors (leaving the builders wedges in place). I then installed terracotta sill tiles (the edges tucked under the bottom sliding door track) across the width of the sliding door assembly removing the builders wedges as I went. Re: New Sliding Door Installation 5Dec 15, 2014 9:21 pm Hi Beetaloo, Thanks for the reply. I have used Structural grout (non shrinking structural cement) before with supporting floor beams. The only other thing I could use would be a SILKA product, I think its a polyurethane product typically used in brick expansion joints which looks like grey "Silicone" but much stronger and has the advantage of waterproofing the underside of the sliding door. I have to decide soon as the bricklayers are starting later this week, Andrew Re: New Sliding Door Installation 6Dec 17, 2014 11:19 am carmania Hi Beetaloo, Thanks for the reply. I have used Structural grout (non shrinking structural cement) before with supporting floor beams. The only other thing I could use would be a SILKA product, I think its a polyurethane product typically used in brick expansion joints which looks like grey "Silicone" but much stronger and has the advantage of waterproofing the underside of the sliding door. I have to decide soon as the bricklayers are starting later this week, Andrew SIKA as in SIKAFLEX? Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: New Sliding Door Installation 8Jan 07, 2015 12:01 pm carmania Hi Ed, Yes, SikaFlex what do you use and recommend? Regards, Andrew Yes, we use that. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 I’m in a similar position except I’m after sliding 3 stacking doors. I am on a second-story apartment of which the balcony would not adequately fit any bi-fold or… 5 16764 DIY, Home Maintenance & Repair Thanks Chippy . Did also see a YouTube video before. Removed them . Thanks again for the advice. 2 14186 |
