Browse Forums Windows & Doors 1 Aug 21, 2013 2:33 pm Hello everyone, I have a sash window with a insect screen attached to the bottom, so when you open the window the screen lifts up with it from inside the brick cavity. I need to replace the cords and as I have not done one of these types I am a bit lost. Any help would be appreciated I use Tramex moisture meter and it will tell me instantly if the wall is cement sheet or plaster or masonite but most people dont have the equipment. 5 8186 Firstly, if your house is still under builder's warranty (10 years in Victoria) you should have no need to crawl into roof space but let the builder handle it, unless you… 3 5870 the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 12691 |
