Jun 20, 2013 1:03 amSign In16 members logged in
Building Forum » Building, Renovation & Maintenance » Windows & Doors
obscure glazed windows
New Topic Post Reply  Page 1 of 1
 [ 8 posts ]
camelia
 Post subject: obscure glazed windows
PostPosted: May 17, 2012 7:06 pm
Hi, does anyone know the existing standards for obscure glass and eye height? This is to provide privacy from windows at first floor level overlooking adjacent properties.
AussieMark
 Post subject: Re: obscure glazed windows
PostPosted: May 17, 2012 9:05 pm
Silver Member
Silver Member
I think in the west anything below 1.6 must be obscured. This is based on my plans and discussion with the window people.
Should be in the r codes or your state equiv.
Not sure that this helps.
Ciao
Mark
camelia
PostPosted: May 20, 2012 7:40 am
Thanks Aussie, what are 'r' codes?
If the average eye height for an australian male is 1.7 (average height of males= 1.8 m) then 1.6 m is inadequate.
ed @ ecoclassic
PostPosted: May 20, 2012 7:58 am
Advertiser
Advertiser
It is 1.7m, so only above average males can perve... apparently they discovered all peeping Toms are short guys...
There's some info here...
Quote:
Overlooking
A habitable room window or raised open space of a building on an allotment must not provide a direct line of sight into the secluded open space or a habitable room window of an existing dwelling on an adjoining allotment within a horizontal distance of 9 metres (measured at ground level) of the window or raised open space.
The direct line of site referred to must be measured with a 45° angle from the plane of window or perimeter of the raised open space and from height of 1.7 metres above the floor level of the habitable room or raised open space.
A habitable room window complies if:
(a) it is offset a minimum of 1.5 metres from the edge of one window to the edge of the other; or
(b) it has a sill height at least 1.7 metres above floor level; or
(c) it has obscure glazing at any part of the window below 1.7 metres above floor level; or
(d) it is obscured by a permanent and fixed screen which has no more than 25% of its area open.
A raised open space complies if the direct line of sight into the habitable room window or secluded private open space on the adjoining allotment is obscured by a permanent and fixed screen which has no more than 25% of its area open.
A window referred to above may be openable provided that when open the obscure glazing does not permit a direct line of sight into secluded private open space or habitable room window.
This does not apply to a new habitable room window that faces a property boundary if:
(a) there is a visual barrier at least 1.8 metres high at the boundary; and
(b) the floor level of the room is less than 800mm above ground level at the boundary.
A raised open space as indicated above means;
(a) a landing with an area more than 2m² and with a floor height of 800mm or more above natural ground level at the boundary; or
(b) a balcony, terrace, deck or patio with a floor height of 800mm or more above natural ground level at the boundary.
If the design does not comply with this a consent and report of the relevant council will be required.
Ed
EcoClassic
Double Glazing in Aluminium & Thermally Broken Aluminium
Replacement Window Experts Including Installation (Melb)
http://www.ecoclassic.com.au
ed @ ecoclassic.com.au
Tel. 1800 326 326
camelia
PostPosted: May 21, 2012 4:11 pm
Thankyou very much Ed for your information. The council has stipulated only 1.6m
AubinGroveFan
PostPosted: May 25, 2012 12:39 pm
Is it compulsory to have obscured glass in the bathrooms if both bathrooms are on the side of the house and there is a colorbond fence?
BUILDING with SUMMIT HOMES.
Our Thread and Timeline
sencillez
PostPosted: May 27, 2012 10:23 am
Junior Member
Junior Member
Quote:
Overlooking
Ed
hi :) would you know if this requirement is also applicable if there's no existing dwelling in the area? (i.e. we are the first ones to build on our block)
thanks in advance :)
ed @ ecoclassic
PostPosted: May 27, 2012 11:18 pm
Advertiser
Advertiser
Yes, it applies to you too...
Ed
EcoClassic
Tel. 1800 326 326
 [ 8 posts ]
Users browsing this forum: No registered users and 7 guests
Read Article: Digitally Print Images On Blinds by Patrenza Blinds VICDigitally Print Images On Blinds
Digitally Print Images & Graphics on your Blinds now available with…
Read Article: Basswood Plantation Shutters by I Seek Blinds TASBasswood Plantation Shutters
Iseekblinds.com.au Just released a new range of Basswood Plantation Shutters at…
Read Article: Choosing the right blinds... by Into Blinds VICChoosing the right blinds...
When it comes to choosing blinds, there is a vast range…
Read Article: External blinds: awnings or shutters? by Into Blinds VICExternal blinds: awnings or shutters?
Awnings are used to shade the windows of a home from…
Read Article: Tips on conserving energy with right blinds and curtains by Arrow Curtains Melbourne VICTips on conserving energy with right blinds and curtains
Did you know that a huge percentage of your heat gain…
Watch Video: Roman Blinds  by Into Blinds VICRoman Blinds
Into Blinds offers a wide range of different fabrics and textures…
Watch Video: Venetians by Into Blinds by Into Blinds VICVenetians by Into Blinds
Venetian Blinds are a great option if you want to add…
Watch Video: Plantation Shutters Video - All you need to know by I Seek Blinds NTPlantation Shutters Video - All you need to know
Plantation Shutters video - In this video Michael talks about the…
