Browse Forums Windows & Doors 1 Aug 06, 2011 10:07 pm Hi all, Just completed part of our selections and am unhappy about my front door. We want one of these ( or similar ) http://www.bunnings.com.au/products_pro ... spx?page=3 In a size of 2360*1020. However it seems that you can't get the glass double glazed. I am doing the rest of my ( small ) house with double glazed windows and really want the front door to match. As a minimum I want 8mm glass purely to reduce sound transmission. The selection's girl rang the supplier and even though in the back of the book they do double/triple glazing, its only on one of there doors. Has anyone seen the door I am after with thick glass or double glazed? Thanks Re: Double glazing timber front door. 2Aug 08, 2011 2:17 pm What about a UV cut reflective tint instead. I think the issue is the thickness (or lack thereof) for double glazing a door. Re: Double glazing timber front door. 3Aug 11, 2011 9:09 pm It the same here. The standard doors of the shelf are a pathetic 40mm thick. Not good for DG or a good multi point lock. Better are the Euro style doors which come in the same designs to choose from but with a decent thickness of 60-70mm. Change is what we need! Can we? YES WE CAN!!!!! Re: Double glazing timber front door. 4Aug 12, 2011 5:08 pm windowexpert It the same here. The standard doors of the shelf are a pathetic 40mm thick. Not good for DG or a good multi point lock. Better are the Euro style doors which come in the same designs to choose from but with a decent thickness of 60-70mm. Don't suppose you have a link do you? Re: Double glazing timber front door. 5Aug 13, 2011 9:50 am http://www.paarhammer.com.au would be the people to talk to in Australia Not cheap as Bunnings but lasting value !! Change is what we need! Can we? YES WE CAN!!!!! This is one of the reasons I decided to go overseas for my double glazed windows. As the builder indicated, he's worked on many upmarket builds, these were the most well… 13 20330 For your reference Performance Labels: Window assemblies in housing, except timber windows, must be labelled so the label can be seen when it is in situ. For timber… 6 10612 |
