May 20, 2013 4:57 amSign In8 members logged in
Find SuppliersPhotosVideosArticlesExpertsForumAdvertise
Building Forum » Building, Renovation & Maintenance » Windows & Doors
Australia's greatest home building and renovation community providing you with access to the popular building forum, planning and budgeting tools, and the premium building directory.
Help with Bay Window replacement
New Topic Post Reply  Page 1 of 1
 [ 17 posts ]
neil100
 Post subject: Help with Bay Window replacement
PostPosted: May 20, 2009 3:59 pm
Junior Member
Junior Member
Hi all,
first post after doing a lot of reading.
We are looking to replace our two bay windows, which are timber, and basically rotten.
I was wondering what sort of ball park figure it would cost to replace them in
a) timber
b) uPVC
c) aluminium
and what people thought about how the aesthetics would be changed using each of these options?
The other important thing for us is that following replacement, we would want to guarantee we could re-use
the plantation shutters fitted to the inside - is this possible with uPVC and aluminium ?
I have (hopefully) attached some pictures to show what I am trying to do and approximate measurements.
Thanks everyone
Neil
ed @ ecoclassic
 Post subject: Re: Help with Bay Window replacement
PostPosted: May 20, 2009 6:20 pm
Advertiser
Advertiser
I have no idea how they are positioned structurally - is there a stud at each corner? Looks like each is 3 separate windows.
Personally - unless you plan to replace the rest of your facade, I would stick to timber (wait... did I just say t-i-m-b-e-r ::surprise:: )
If it has studs at the corners it's fairly simple. Guessing $3,000 each bay including installation.
Ed
EcoClassic
Double Glazing in Aluminium & Thermally Broken Aluminium
Replacement Window Experts Including Installation (Melb)
http://www.ecoclassic.com.au
ed @ ecoclassic.com.au
Tel. 1800 326 326
neil100
PostPosted: May 20, 2009 9:33 pm
Junior Member
Junior Member
Hi Ed
Sorry, but what do you mean by "stud" at each corner.
Would I be able to get double glazed units with timber ?
Thanks for the reply.
Neil
ed @ ecoclassic
PostPosted: May 20, 2009 10:51 pm
Advertiser
Advertiser
neil100 wrote:
Hi Ed
Neil
Hi
A stud is the vertical timber in your house frame. I am guessing that your bay window is 3 separate windows nailed into the house frame, rather than a complete assembled bay window.
Yes, they do double glazed timber windows.
Ed
EcoClassic
Tel. 1800 326 326
neil100
PostPosted: May 21, 2009 9:22 am
Junior Member
Junior Member
Ed
Wow ! - i'd be pretty happy with that sort of price.
Anyone else thinking in this ball park ?
Thanks
Neil
neil100
PostPosted: May 26, 2009 1:04 pm
Junior Member
Junior Member
Ed
Hi Ed
Just curious why you think this? Is it because you
Think upvc would look out of place?
Regards
Neil
ed @ ecoclassic
PostPosted: May 26, 2009 4:39 pm
Advertiser
Advertiser
Ed
Hi Ed
Regards
Neil
The weight of the timber sections balance between ground & 1st floor, & you can easily paint timber any colour.
To change just the ground floor to PVC will mean you will need to paint your timber windows to match. And you will need to accept the different look.
If you plan to eventually replace all facade windows, then go with PVC IMO.
Ed
EcoClassic
Tel. 1800 326 326
neil100
PostPosted: May 26, 2009 5:26 pm
Junior Member
Junior Member
[/quote]
Ed[/quote]
This might be a possibility, however, one of my caveats is that we can re-use out internal plantation shutters.
What's your take on whether
a) uPVC windows could be made to a similar sort of design as the existing timber ones
b) we can re-attach the shutters to uPVC windows
Many thanks Ed.
Neil
ed @ ecoclassic
PostPosted: May 26, 2009 11:23 pm
Advertiser
Advertiser
Ed
Many thanks Ed.
Neil
Hi Neil
uPVC windows are not in any way customisable except for size. Having said that the profiles replicate heavy timber. Best bet is to measure your jambs, to get a feel for the differences.
Same goes for your plantation shutters. I would think that the top, bottom and side rails could be cut to fit within reason. So measure and check it out. If the shutters were to be too small then that would be a problem, but too big maybe they can be trimmed. Hopefully they are timber?
Ed
EcoClassic
Tel. 1800 326 326
neil100
PostPosted: May 27, 2009 10:54 am
Junior Member
Junior Member
[/quote]
Ed[/quote]
Hi again Ed,
for a bay window then, which I understamd is essentially 3 spearate windows, how (using uPVC)
would the two side windows be joined to the middle window to provide a seal ?
Would a uPVC bay window be installed as 3 separate windows, or as 1 complete unit ?
Many thanks
(oh, not sure if you follow football, but congrats on Sunderland staying up and with Newcastle going down
it must have been pretty wild up on Tyneside!)
ed @ ecoclassic
PostPosted: May 27, 2009 11:32 am
Advertiser
Advertiser
Hey - that's great... haway the lads... ::
Now what was your question again :D
EcoClassic
Tel. 1800 326 326
ed @ ecoclassic
PostPosted: May 27, 2009 11:34 am
Advertiser
Advertiser
That was my original point - it looks like your bay windows are 3 separate windows, meaning there is a stud at each corner. That makes it easier. So you install 3 windows rather than one, and the gap/join is covered by timber - as it is now.
Ed
EcoClassic
Tel. 1800 326 326
neil100
PostPosted: May 27, 2009 12:27 pm
Junior Member
Junior Member
Ed
OK, so looking at your product sizes, if I was looking at double hung,
2 off 1543 x 610 and 1 off 1543 x 1450 - what sort of price would that be delivered to Sydney?
Do you have any contacts for installation in Sydney Metro area ?
Do you know anything about these suppliers product http://www.easywindows.com.au/ ?
Thanks
Neil
ed @ ecoclassic
PostPosted: May 27, 2009 3:01 pm
Advertiser
Advertiser
Ed
Thanks
Neil
I am sure that double hung will not provide enough cover for your shutter to attach. I have priced the awning or casement.
    2 @ $400 each
    1 @ $690
Standard sizes, includes timber colour to outside, white inside.
Courier or delivery at cost...
Sorry I don't know any installers in Sydney - a carpenter could easily do the job. But he should check measure and specify the size so he takes responsibility.
The window co you refer to uses Kommerling so the quality will be good.
Thanks
Ed
EcoClassic
Tel. 1800 326 326
neil100
PostPosted: May 27, 2009 9:35 pm
Junior Member
Junior Member
[/quote]
    2 @ $400 each
    1 @ $690
Thanks
Ed[/quote]
Thanks Ed
Are you able to add colonial bars to the windows ?
I must admit, I do like the wood grain effect. On the website it
Looks really good. Would like to see it in the flesh.
Regards
Neil
ed @ ecoclassic
PostPosted: May 28, 2009 7:25 am
Advertiser
Advertiser
Hmmm there is definitely somthing wrong with the quoting in Homeone - it gets in a knot these days...
Anyway, yes, we can do colonial bars in between the glass - BUT only in white. So a timber look with colonial bars is not available.
If you PM your address I can send a colour sample in timber...
Ed
EcoClassic
Tel. 1800 326 326
neil100
PostPosted: May 29, 2009 4:26 pm
Junior Member
Junior Member
Ed
Thanks - PM sent ED
 [ 17 posts ]
Users browsing this forum: No registered users and 3 guests
homeone® - Australia's home building and renovation resource.
home building and renovation directory
Read Article: Digitally Print Images On Blinds by Patrenza Blinds VICDigitally Print Images On Blinds
Digitally Print Images & Graphics on your Blinds now available with…
Read Article: Basswood Plantation Shutters by I Seek Blinds TASBasswood Plantation Shutters
Iseekblinds.com.au Just released a new range of Basswood Plantation Shutters at…
Read Article: Choosing the right blinds... by Into Blinds VICChoosing the right blinds...
When it comes to choosing blinds, there is a vast range…
Read Article: External blinds: awnings or shutters? by Into Blinds VICExternal blinds: awnings or shutters?
Awnings are used to shade the windows of a home from…
Read Article: Tips on conserving energy with right blinds and curtains by Arrow Curtains Melbourne VICTips on conserving energy with right blinds and curtains
Did you know that a huge percentage of your heat gain…
Watch Video: Roman Blinds  by Into Blinds VICRoman Blinds
Into Blinds offers a wide range of different fabrics and textures…
Watch Video: Venetians by Into Blinds by Into Blinds VICVenetians by Into Blinds
Venetian Blinds are a great option if you want to add…
Watch Video: Plantation Shutters Video - All you need to know by I Seek Blinds NTPlantation Shutters Video - All you need to know
Plantation Shutters video - In this video Michael talks about the…
