Browse Forums Windows & Doors 1 Apr 22, 2024 9:29 pm My door tends to rub against the frame during winter and I'm looking to fix it so it closes smoothly. Looking online on Youtube I'm seeing methods to fix the alignment and I have tightened the screws which has helped somewhat. However the door is sloping away from the top most hinge which I suspect is the most common problem over time. A lot of the methods I see suggest to take out the hinge pin and re-align the hinge however because I have a fixed pin I'm unable to do that. Is there something else I could do to try make my door close smoothly? I've thought about sanding the edges of the door but I'm wondering if there's something better I could try first. These are photos of small sections as I don’t want to identify myself yet. All frames in the house have cement/mortar all over them, have had for months & months.… 2 1096 1) I had requested R6 ceiling insualtion batts, however I noticed that on some areas there are huge gaps which will allow hot air to sweep in, and also noticed black/grey… 0 4659 Thank you so much everyone. This all makes a lot of sense. I guess when you talk to a builder who butters up everything to look very polished, you get to start believing… 7 19246 |
