Browse Forums Windows & Doors 1 Feb 06, 2024 6:47 am Hi, got a new build with external timber walls and cladding. Will soon be installing windows. Was wondering what is best to use for external architraves? Want square architraves, about 70x19. Options seem to be pine mouldings(LOSP), Tasmanian oak, hardwood or something like Hardie Axent Trim(fibre cement). I think pine is not a good choice for external, will not last that long? Or will LOSP pin be OK. Merbau would be good, but I think painting it is tricky. I was told fibre cement option like Hardie Axent is difficult working with. So, I was thinking to use a hardwood. Would Tasmanian Oak be a good long lasting option? I see it is not as dense as other hardwoods like blackbut or merbau. Or will it be similar to pin LOSP mouldings? Re: External architraves for window 2Feb 06, 2024 11:15 am Cedar? Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog I do like the CA glue and activator idea but like you said, working time in non existent. I use the sika PU glue but it needs to be clamped firm. I had a joint move… 4 9294 I already have the doors and architraves installed as pictured. My question is which size n type of skirting would go with the architraves? I originally wanted a winder,… 0 3328 Before you rip it up, if you can in the grout lines, drill some holes and pour/inject techgrip by sika. I have used it to bond mdf to timber, but in the process it dripped… 1 4502 |
