Browse Forums Windows & Doors 1 Nov 27, 2023 8:45 pm I've recently had some windows installed, and the larger ones are causing the bottom window reveals to bend upwards significantly. I suspect this is partly due to weight, as the glass and frames are not supported by anything other than the timber reveal, but also improper packing. The photos below were taken before the builder attempted to fix this by simply screwing down the reveals, which now results in a very wavy looking reveal (sorry, no pictures of this). What would have caused this issue in the first place, and what's the correct way to resolve it? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Heavy windows with bent reveals 2Nov 28, 2023 1:03 pm wixy I've recently had some windows installed, and the larger ones are causing the bottom window reveals to bend upwards significantly. I suspect this is partly due to weight, as the glass and frames are not supported by anything other than the timber reveal, but also improper packing. The photos below were taken before the builder attempted to fix this by simply screwing down the reveals, which now results in a very wavy looking reveal (sorry, no pictures of this). What would have caused this issue in the first place, and what's the correct way to resolve it? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ What size are the windows, double or single glazed, can I have a pic of the full windows inside & out? If you can see packers please take a pic. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Plasterboard Gyprock is very popular as a reveal liner these days. You need to provide a way of supporting it, we use a modified timber reveal or bracket. You will be… 1 4972 Firstly, if your house is still under builder's warranty (10 years in Victoria) you should have no need to crawl into roof space but let the builder handle it, unless you… 3 5808 Hi, I'm planning to build a new house and wanted to get some feedback on the different window designs for a master bedroom. Our bedroom is north facing and the bed will… 0 4727 |
