Hi,
Which glass is better sturdier for 1.5m wide 3 panel door stacker doors, 6mm toughened or 10mm laminated ?
Browse Forums Windows & Doors Re: Which glass for stacker doors 2Oct 26, 2023 12:46 pm What do you need them to withstand? If it's normal wear and tear, then either will do, if you want resistance to ingress then laminated would be the favourite, but only if the laminate is bonded to the frame. If it's not bonded then the glass can collapse into itself when broken, and it would be easy to break-in. It is surprising what toughened glass can bear as a load or impact. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Sure looks like the type of track that I fitted to my house. My supplier said that the underside has a tray which drains to the front. They cut vertical slots in it. So as… 6 7951 Need to remove glass panel out of concrete without wrecking the glass to get the spa room in, any recommendations on how to do that. Thank you 0 39100 |
