Browse Forums Windows & Doors 1 Aug 12, 2023 4:25 pm Re: Sliding door -no roller screws 2Aug 12, 2023 5:43 pm It's a bit hard to make out from the photo but it looks like the spindle on the roller is just a captive pin. I'd expect that you angle a screwdriver through the slot in the side of the door and under the roller and then lever up. The roller and spindle should hopefully pop out. Then get a matching size roller, line its spindle up with the slots and tap it back in so it's clipped in. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Sliding door -no roller screws 3Aug 12, 2023 6:35 pm chippy It's a bit hard to make out from the photo but it looks like the spindle on the roller is just a captive pin. I'd expect that you angle a screwdriver through the slot in the side of the door and under the roller and then lever up. The roller and spindle should hopefully pop out. Then get a matching size roller, line its spindle up with the slots and tap it back in so it's clipped in. Thank you!!! Sam There is a much stronger glue than liquid nails. It's called T Rex and will stick your timber to the concrete. Cheers Simeon 1 1666 l spoke to my plumber we decided to replace the rusted screws and keep all the screws with no rust, it will only cost a few hundred 7 9055 |
