Browse Forums Windows & Doors 1 Jul 13, 2023 10:38 am Hi all, On one of the aluminium awning windows in my property, the rubber seal that runs around the window itself has popped out in one corner. I've tried for 10 mins but I can't for the life of me get it back in. See photo: https://i.ibb.co/GkhK1zP/IMG-4418.jpg Could anyone give me any advice on how to pop it back in? Maybe there's a tool I need? The rubber itself doesn't seem to have degraded, so I don't think a completely new seal is necessary. Property is about 7 years old. The loose seal doesn't impair the window from closing, I just know that if I don't fix it it'll keep getting worse. Thanks. Re: Aluminium awning window seal has popped out in one corne 2Jul 13, 2023 1:09 pm yesplease Hi all, On one of the aluminium awning windows in my property, the rubber seal that runs around the window itself has popped out in one corner. I've tried for 10 mins but I can't for the life of me get it back in. See photo: https://i.ibb.co/GkhK1zP/IMG-4418.jpg Could anyone give me any advice on how to pop it back in? Maybe there's a tool I need? The rubber itself doesn't seem to have degraded, so I don't think a completely new seal is necessary. Property is about 7 years old. The loose seal doesn't impair the window from closing, I just know that if I don't fix it it'll keep getting worse. Thanks. should just be able to jimmy it back in with a flat head screwdriver Re: Aluminium awning window seal has popped out in one corne 3Jul 13, 2023 1:21 pm yesplease Hi all, On one of the aluminium awning windows in my property, the rubber seal that runs around the window itself has popped out in one corner. I've tried for 10 mins but I can't for the life of me get it back in. See photo: https://i.ibb.co/GkhK1zP/IMG-4418.jpg Could anyone give me any advice on how to pop it back in? Maybe there's a tool I need? The rubber itself doesn't seem to have degraded, so I don't think a completely new seal is necessary. Property is about 7 years old. The loose seal doesn't impair the window from closing, I just know that if I don't fix it it'll keep getting worse. Thanks. brush hot soapy water on the rubber then it will be easier to push it in Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Aluminium awning window seal has popped out in one corne 4Jul 13, 2023 8:34 pm ponzutwo should just be able to jimmy it back in with a flat head screwdriver Yeah I had already tried that, still couldn't get it in. I felt like I was going to tear the rubber. building expert brush hot soapy water on the rubber then it will be easier to push it in Cheers, I'll give that a try. For your reference Performance Labels: Window assemblies in housing, except timber windows, must be labelled so the label can be seen when it is in situ. For timber… 6 10406 I need to replace the worn mohair seal on my sliding window, but I can't get access to the end to slide the old one out & push the new one in. I could probably rip the old… 0 5413 Dear all, Requesting your help in relation to a CDC code. We are building a new home in NSW on a corner lot (500m2, 15m wide) following Greenfield CDC code. Our design… 0 6361 |
