Browse Forums Windows & Doors 1 Oct 28, 2022 6:48 pm Hi. I am after something to property fill and seal the gap around all my windows. Water is coming in through the frame when it rains. House is old so and just about to be rented. All windows are like the ones pictured. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Exterior window frame gaos 2Oct 29, 2022 6:29 pm I can't understand what I am looking at, is the window not installed into the wall? Anyway, don't use polyurethane sealants they have a life of around 7 years, use silicone instead... But before you do you might look at how the window is installed. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Exterior window frame gaos 3Oct 29, 2022 6:49 pm ECOECO I can't understand what I am looking at, is the window not installed into the wall? Anyway, don't use polyurethane sealants they have a life of around 7 years, use silicone instead... But before you do you might look at how the window is installed. Hi. I don't know either all my windows stick out this much. Re: Exterior window frame gaos 4Oct 31, 2022 10:08 am smity82au ECOECO I can't understand what I am looking at, is the window not installed into the wall? Anyway, don't use polyurethane sealants they have a life of around 7 years, use silicone instead... But before you do you might look at how the window is installed. Hi. I don't know either all my windows stick out this much. Well they should not, this is your cause of your leaks. If you are not familiar with what you are looking at, find someone who is because this is not an easy fix. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 This is 100% true. You can not hang anything on steel frames. very frustrating 8 10383 Its the flashing and is normal. Some builders cover them up others just leave them handing. You can cover it up with an aluminium bracket or ask the builder. 7 11801 1 14694 |
