Browse Forums Windows & Doors Re: Retrofit flashing in Double Brick Home 3Jul 15, 2020 12:21 pm HomeDIYER We are considering to retrofit some new exterior windows into our double brick home. Outside skin is face brick. What is the standard procedure here for retrofitting flashing? Seems the head, jamb and sill flashing is generally installed during construction? Would we have to remove a further 2 courses above window/door locations to install new flashing? I'd prefer not to do this though. Thanks in advance! You should only need to seal the window into the outer bricks by caulking around it. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Coming back to this.... When installing a pressure flashing, what fixings would you use (please give a link) ? Above Pedro said nylon anchors. Anyone have a preferred… 7 11837 I know this post is from a while ago, but the VBA has some good guidance on this. https://www.vba.vic.gov.au/__data/asset ... 5-Roof.pdf 2 11480 AFAIK, flashing is a minimum standard. Out of curiosity is your window glass stamped with AS requirements in any of the corners of each pane? Im almost certan if theyre… 2 6840 |
