Browse Forums Windows & Doors Re: Which is better in a cyclone: louvres or sliding windows 2Jul 25, 2016 3:13 pm gommeqld Wondering which is the stronger and less leaky in a cyclonic area. I've seen arguments for both. My feeling is sliding windows would be stronger simply because the panes are framed around the whole perimeter but I've seen reference to a report where the sliding window weep holes allowed water ingress during high winds. Does anyone have direct experience or an "authoritive" / "expert" conclusion ? You need to see the test report from the tested window/louvre. It will tell you everything. Sounds like you need windows to at least N4. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Bigger the better for storage for me IMO. But I guess it's harder to tell the cost/benefit in your example - mainly the 'cost'? If you go 700mm, what are you doing extra… 2 3072 4 2202 Canopy and Undermount are best, and need to be ducted externally. Which one you go with will be largely determined by your design and joinery choices. What you should be… 1 1624 |
