Browse Forums Paving & Concreting 1 May 31, 2020 8:54 am Hi everyone, Due to lots of factors (mainly the laziness of more than one concreters and I was not at home to supervise), I'm now living with a non compliant concrete footpath of 10m x 1m x 0.1m at the back of the house. The problem is that its only 35mm from the weepholes/DPC instead of minimum 50mm (in low rainfall area, not sure if mine is)/75mm as per standard. Due to the small size of the project, it's very unlikely that the concreters will come back to redo it. It's also very costly and time consuming to dispute via authorities. It's also too much expensive for me to hire someone else rip it up and do again So I'm now seeking to evaluate the risks and what I can do to mitigate (not eliminate) them and your input will be valuable. My questions are: 1. Since the weepholes are still visible and still 35mm from the concrete which slopes away, what kind of risks are we talking about here? 2. What else can we do to mitigate those risks? Will a cover extension help in that manner? 3. Is it so critical that I seriously should think about demolishing it and doing it all over again? Thanks so much guys Re: Concrete path insufficient clearance from weep holes - N 2May 31, 2020 10:48 am Risk is mitigated if the path has a slope, the required slope is 1:20 over the first metre away from the house, i.e. 50mm over 1 metre. What slope do you have and do you know the soil classification? Also, is water likely to dam at the side of the path? If you are Sydney metro, definitely not a low rainfall intensity area which has a 1:20 Average Recurrence Interval of 120mm or less per hour based on an average rainfall intensity of 2mm per minute over a 5 minute duration. What termite protection do you have? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Concrete path insufficient clearance from weep holes - N 4May 31, 2020 11:07 am Your 1:20 ARI is 170mm/h. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ At least your path has a slope. Provided the water doesn't dam at the edge, you should be alright but it isn't ideal. The Standards are the minimum requirement. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. You are correct. Just read through all the ncc rules and 75mm is the minimum requirement for me. 4 11934 it depends on the natural ground level, if they excavated their boundary wall needed to be built as a retaining wall. If you filled, which sounds like the case then you… 1 7557 I know foam has been around since the 90's and CSR started manufacturing Hebel in 1989, so it's definitely possible 5 6130 |
