Browse Forums Paving & Concreting 1 May 04, 2020 6:04 pm Re: Cracks in slab 2May 04, 2020 7:41 pm If they were related to an issue with the underlying ground (assuming its the ground floor) you would expect other indications elsewhere e.g cracks in walls, sticking doors etc. You would also expect some sort of common pattern or alignment to them if it was related to poorly compacted fill or soft ground etc. If these characteristics are not present it's probably related to the concrete (e.g shrinkage cracks) rather than a deeper-seated problem with the ground. Not really answered your question but it's a process of elimination. The CSIRO BTF18 explains differnt types of cracks and what "normal" is Google this and the top result is actually the latest version. You normally have to buy this from… 9 9590 It sounds like you have a crack in your garage where the wall meets the ceiling, along the shadow line on the… 0 17868 Do you have a scope of works? If have texture on wall now, the patch will show through The standard for repair of texture is to patch, re-texture corner to corner,… 5 7296 |
